Going back to 94170015
The rev limits are working for me on my 03. Idle is not quite as smooth. No BISS adjustment.
Yet to experience the throttle hang...yet. Made changes for that here
https://www.evolutionm.net/forums/7859772-post410.html
This is really wierd. Appauldd I would be curious to compare your rom to mine. I will PM you my email.
Isn't the V6 based on the 9653 rom?
Can you post or send me the xml and or the address for the tables??
As for the "issues" being small, yes they essentially are. The thing is that "issues" continue to come up. I am just getting tired of working to solve the "issues" all of the time. I want to work on tuning my car rather than fixing problems.
It does seem that 03-04 VIIIs see the majority of the problems with v7 9653. I would assume it has to do with the difference as mentioned above.
If all goes as planned I should be able to do everything that v7 9653 can do here soon.
Anyway.....
I am really just looking to get some addresses for the tables in the OP.
2. Car has ran better than stock ecu since day 1.
3. Yes I got my emissions sticker last year and will get another this year.
I think you just need to spend a little more time with the rom. My friends 03 evo is having no problems with V7 and travman is having no issues with the evo 8's he has used it on.
Do you realize how much "time" I have put in to resolving the issues and finding solutions with v7?
Anyway....back on topic.
Does anyone have addresses for 94170015 for the tables in the OP???
maybe i can add in my experiance with SD on a 2003 evo8.
i have not had good luck at all with it other then WOT. my issues are
1. idle is 2k to 3k all over the place
2. when i am trying to leave from a stop it go's extremely lean and brakes up until it gets past 4krpm. if i am on a hill the car will NOT make it as it just cuts out. i cant even get up my driveway.
3. when driving and maintaining speed the car is very rich. 10.8 11.2 area
i have done boost leak tests. i have no leaks. i have changed and replaced sensors and that did not help. i have the AIT and Omni 4 bar map sensor.
my intake manifold is Driven Innovations with AIC and a hypertune 3.0 TB.
Tephra....c'mon man We never mentioned that. SHHHH
But just to let you know....IT WORKS PHENOMENAL ! !
If I can get the rest of the addresses in the OP, I believe I have 94170715 100% operational.
