94170715 V7 Issues
THANKS ACAMUS ! !
Below are the ISCV Demand adder tables that he and I worked to make for 9417. Any not in this list are still being worked.
<table name="ISCV Demand Below 500 RPM Idle Recovery Adder (sub_1A51A)" category="ISCV Control" address="1916" type="1D" level="2" scaling="ISCV_AX2_16"/>
<table name="ISCV Demand Startup CTS Adder (sub_1AE40)" category="ISCV Control" address="42ae" type="2D" level="2" scaling="ISCV_AX2_8">
<table name="Coolant Temp" address="67a2" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="ISCV Demand General CTS Subtractor (sub_1AE6E)" category="ISCV Control" address="4372" type="2D" level="2" scaling="ISCV_AX2_8">
</table>
<table name="ISCV Demand Baro Adder (FFFF8C9A) (sub_1A61C)" category="ISCV Control" address="4339" type="2D" level="2" scaling="ISCV_AX2_8">
<table name="Baro" address="6608" type="Y Axis" elements="5" scaling="Baro16"/>
</table>
<table name="ISCV Demand RPM Adder* (sub_1B1DA)" category="ISCV Control" address="47d6" type="2D" level="2" scaling="ISCV_AX2_8">
<table name="RPM" address="635a" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="ISCV Demand CTS Adder #1** (sub_1AC3E, sub_1B3CC, sub_1B664)" category="ISCV Control" address="4276" type="2D" level="2" scaling="ISCV_AX2_8">
<table name="Coolant Temp" address="6884" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="ISCV Demand CTS Adder #1a*** (sub_1B424) " category="ISCV Control" address="5564" type="2D" level="2" scaling="ISCV_AX2_8">
</table>
<table name="ISCV Demand CTS Adder #1b*** (sub_1B424)" category="ISCV Control" address="4292" type="2D" level="2" scaling="ISCV_AX2_8">
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
I think Jim was referring to the "Lean Spool Stop RPM" table.
In 94170715 I removed the Boost Enhancement (anti-lag) Start and Stop RPM tables. Adjusting those table proved to enhance nothing and only create issues.
EvoM Community Team
He is probably working off an old set of definitions, as the v7 of yours I downloaded a few days ago was set to 7000 with the current/correct definitions (and 4531 with whatever old definitions I had).
Care to share your uber xml??? I have to admit there are a few aspects of the evoscan maptracer that I miss. Like being able to mouse over a cell and see all of the values that have occured in that cell for the log.
The size of the bigmaps is a bummer on a netbook though. Along with the inability of being able to reestablish the xml for a given rom. Ugh.
I did notice that 94150715 <inherited>94170015</inherited> which <inherited>evo7base</inherited>.
EDIT
I did notice that 94170015 V7<inherited>94150015</inherited> which <inherited>evo7base</inherited>.
When I took the basic 94170015 to build up 94170715. I took the premise that was done in previous v7 roms to build only 1 xml for the rom to run with. The goal was to eliminate all of the <inherited> that was being done as patches were developed.
If I'm misreading something, please advise. Thanks.
EDIT: Please disregard.
If you are using lean spool it is a good idea to raise it over your rev limit so you do not go off lean spool at the top of the rev range. It makes tuning the top end more difficult to tune if you do not.
I can post the xml i have that works with evoscan - still working on getting all the new tables found for 94170015 into it.
You can see in the dyno sheets when someone has LS on and goes past the rpm cut off. The sheet will show a dip in power at top end.
I believe I may have suggested this when I wrote the Tuning with LS enabled thread.
Anyone running into any 9417 v7 "issues" ? ? ?
