What happend with my map?
It just means the map doesn't have a full set of parameters. If you click on edit, you'll see the current, incomplete definition. If all your main maps are OK, I wouldn't bother getting a new xml. ECUflash remembers the xml it last used for a ROM, so if you want tyo force it to use a new xml, you have to do something like zip the old one ( to back it up) and then delete the old unzipped file, then paste in your new xml, or change the extention to .txt
Thanks guys, but everything is ok. This map was look like this only after read without saving. When I save it on my laptop and open again - everything is ok. Thanks !
I think it happend because she was created on other laptop (my friend's) which could have other xml's.
Hello. I am updating this thread because I had some problems with my boost. After re-tune with my friend's laptop, I've read my rom image to save it for future on my laptop. I was send it to ECU when my battery died to have sure, that my ECU have right map. Then I observed, that my boost is only 1 bar (that is my wastegate spring). On dyno we set 1.6 bar. So I've changed wgdc values to see if it react and yes - my ECU read new settings and my boost goes up.
Is it possible that because of other xml's on my laptop and my friends laptop (where my map was created) my ECU doesn't reading my boost map correctly?
So what could be reason that now my Grimmspeed BCS needs 75% wgdc to make 1.6 bar, however eariler it needs only 60%? What could hapenned ? Other air pressure that on dyno?
I've checked everything :/. When my wgdc was 60% - I had 1.6 bar. Now it holds clear 1 bar like my wastegate spring (@60%). When I've changed to 75% it shows about 1.6 bar.
Thank You. I should say also, that this problems begin from moment when I by mistake make few pulls with water injection "on". I've noticed that after first problems, when I could not get any boost. My engine doesn't works good and turbo could not spool. When I've turned it off, engine worked ok, boost was ok, but I didnt drive my car for few days. I don't know what could this water cause.
I'm not using water injection - just installed it for now, but system works and I had distilled water in.
Maybe this info would be interrest: I've opened my Grimmspeed and found few teflon pieces that producer using to threads. I cleared it, but noting's changed, but maybe this valve doesn't work correctly
