How to Eliminate "Rev-Hang" on the 05+ EVO 8/9s
Old Jul 17, 2013, 07:07 PM
  #31
Blitz's Avatar
Figured out both questions. Reinstalled ECU flash /Tephra and can see tables fine now. And when you edit Decel Fuel Cut Delay tables the ISCV Demand TPS Adder tables change automatically. Now to go try this. Thanks!
Old Jul 17, 2013, 08:28 PM
  #32
Blitz's Avatar
My rev hang is 100% gone. Can't believe it. Just this morning I was thinking if I can't make it go away I'll sell the car and get a GT-R or something someday. Was totally sucking the fun out of driving a manual.
Jay I sent $10 your way on PayPal. Get yourself a six pack on me.
Old Jul 17, 2013, 10:18 PM
  #33
Boosted Tuning's Avatar
^ Thanks. Glad it helped you out.
Old Jul 17, 2013, 11:12 PM
  #34
evobros's Avatar
Originally Posted by evobros
I'm having this same problem but my car is stock with stock tune. Any ideas?
Anyone???
Old Jul 18, 2013, 08:22 AM
  #35
fireroasted's Avatar
Anyone???
If you are looking for a cause of the type of behavior described, the engine accelerating off throttle, consider what might be happening to make it accelerate. One factor is that it's behaving as though you have your foot on the gas still, correct? This is essentially air is getting through the intake as if the throttle plate is still open. This path of thinking is what the code fixes address, but it could also be air getting in after the throttle plate. Any super en leaning condition will make the motor accel with the clutch depressed (no resistance on the motor).
Check for boost leaks after the TB. All those tiny ERG hoses and fittings, can leak a little bit and you will still drive relatively fine with boost pressure but they will leak in vacuum as well. Off throttle after a big pull creates a lot of sudden vacuum which will pull in air for a few seconds enough to rev up an engine that is not connected to the driveline.
Old Jul 18, 2013, 05:38 PM
  #36
CRONZ305's Avatar
Oh my gawd thank you!!!!
Old Jul 28, 2013, 10:48 AM
  #37
catman78's Avatar
anyone have the definitions for
94170715
thanks
Old Jul 28, 2013, 10:50 AM
  #38
94170715
thanks
9417 doesnt have the rev hang, so this isnt needed.
Old May 26, 2015, 03:58 AM
  #39
Pyatka-ubiyca's Avatar
Hello everyone!
How i can correctly resolve problem (rev hang) on my 88580714 rom?
In my 88580714 i dont see tables from this guide
http://2.firepic.org/2/images/2015-0...og56zv8y9b.png
thats all what i have
Maybe exist custom XML definitions with those tables (i searched... but with no result )
if EDM roms don't have solution, can i use USDM rom on my car?
Anybody know "true way" for fix rev hang.. for EDM roms
Thank for answer!
Old May 28, 2015, 12:00 AM
  #40
Originally Posted by Pyatka-ubiyca
Hello everyone!
Thank for answer!
You would have to find those tables for that ROM. If you search around, you can probably find them.
Old Oct 27, 2015, 06:56 PM
  #41
imdrax's Avatar
What tables would I adjust to fix this for an Evo X?
Old Oct 31, 2015, 06:06 AM
  #42
Registered User
kaganader2's Avatar
Throttle tables...
Old Jul 10, 2017, 02:04 PM
  #43
06_SSL's Avatar
My solution
Mine felt like it stayed where it was when I lifted to shift, tried some different things but the fact it felt as something was pushing or pulling on throttle plate disturbed me. So I added a spring from throttle arm to the strut tower brace (temporary nd better mounting solution) and it drives awesome now. Had car for awhile and thought throttle felt light the whole time. Just my .2¢
Old Jul 10, 2017, 02:39 PM
  #44
kyoo's Avatar
pic?
Old Jul 10, 2017, 04:52 PM
  #45
06_SSL's Avatar
Pics
Ugly I know, but it sure snaps the throttle closed. That's why I need a better way to mount. But you get the idea
Quick Reply: How to Eliminate "Rev-Hang" on the 05+ EVO 8/9s
