EVO VIII SD Problem
EVO VIII SD Problem
Hi currently running a 2003 Evo
Mods in sig
Just began getting my build wrapped up and now im in transition to SD.
Recently added a WB 450lph FP and FIC Bluemax 1450cc injectors
I also had to remove my afpr because it wouldnt read any psi on first startup during idle so im currently on stock FPR
Anyway I start the car with the SD map for first time and get an idle AFR of 10.9 and when I push hard on the gas the car bucks and stalls. When I gently apply gas the car will rev to 5k normally then sputter.
So I chang VE RPM @ 1250 and 1500 to 75 through much trial amd error and got AFR to 13.4 but still no change in WOT bucking.
The car will shake and almost stall completely with any sudden throttle and hasn't moved and inch under its own power in days.
Any ideas? I have had so many problems with this build. Im desperate.
Mods in sig
That's what I thought as well? Which is why I tried 1329 and 1460 both yielded rich conditions
Wideband jumps to 17 then bucks and reverts to 22.4 because the car dies for about 3 sec then AFR drops to 11.1 at idle for 2 min and will slowly climb but never back above 12 after I rev it unless I shut the car off.
Also I will look into proper map scaling I got the basemap from a friend who has an identical setup just not FF and he's been driving circles around me.
This might be a bit out there, but prior to swapping out the injectors, were you running SD or on the MAF? If you were running on the MAF, it might be worth it to throw the old injectors back in the car in order to have a baseline to tune against. Once the car is running good and the tune seems square, then drop the 1450s back in so that you only have to deal with one set of variables at a time.
Again, that's just my thought process.
Update... after waking up @ 6am to get to the shop on Sunday to review data
Map sensor scaled correctly I went word for word via tutorial just to make sure I wasn't missing something I didnt understand.
Im going over the the cars ecu. And it was in closed loop. I didn't think of it since the map was working on my friends car. So im changing the values now to run open
However im slightly suspicious of the new fuel pump or something along those lines.
I tested the brand new fuel pressure gauge with a compressor and it works.....so why would the afpr read 0 and why only when I step on it is it choking. The STM rewire kit is wired in properly the fuel pump is in and not leaking.
Still going forward with running open loop will report back
It's choking when you step on it b/c you're flooding the cylinder with fuel. I ran into this issue when I disabled Lean Spool on my car. The car drove great at part throttle, but as soon it went WOT it would bottom out the AFR (7.9 on my LC-1) and immediately go lean and felt it like you were trying to pull a semi with the car.
With the AFPR, was the plumbing correct? Does your fuel rail have a port to mount the gauge? If it does, have you tried to mount the gauge directly to the fuel rail to check it?
I had an aem fuel rail with a port however during installation we had one of the factory screws used in mock up shear in the rail so I switched it to the stock one for now.
I used a MAP kit I had one side port blocked one side port from passenger side rail and bottom port was sent to return everything is plumbed with 6an stainless teflon brand new and purged.
Update
so first thing I noticed post leaving the shop and looking over the map was that MAP MID MAX VE was 4.80 instead of 4.90..... I am running a 4BAR
could that cause the sputtering? Only reason i ask now is i really don't want to blow another day of shop time on my own car unless I can have some info on the 4.80 causing the problem I have been having.
Open loop yielded no change
fine part throttle revs while stationary but a WOT stationary rev causes the car to sputter and cut out.
Let me know if you need VE table pics
Also been toying with latency's does anyone have an opinion on these?
Any help I'm grateful and sitting with open eyes
thanks
thanks
If everything was scaled to a 5 bar map sensor would that be causing my issue?
I just looked into
Boost error, desired and alternate boost settings
All were scaled to a 5 bar instead of OMNI 4
I won't know until tomorrow myself but just trying to get an idea ahead of time.
I just looked into
