How to use Virtual Dyno Properly
Old Jul 7, 2012, 05:37 PM
Drill_Sergeant's Avatar
when you load up multiple logs onto VD, it will auto set different colors to differentiate between logs.
Old Jul 7, 2012, 06:16 PM
EvoIIIAj's Avatar
Awesome thread fellas!
Old Jul 8, 2012, 12:47 AM
tscompusa's Avatar
did you notice im using one of your graphs we made at the drag strip when we were tuning? lol.. the high HP graph is from your car.
Old Jul 8, 2012, 09:29 AM
VIIIdriver's Avatar
Thanks so much for posting this thread guys,lots of good info here
Old Jul 8, 2012, 12:36 PM
wizzo 8's Avatar
Yes I realize that. I was just wondering how do you change the color from red to something else if you only have one graph up?
Old Jul 9, 2012, 01:45 PM
Raptord's Avatar
Great thread gentlemen, looking forward to reading in more detail when I get the chance.
Old Jul 12, 2012, 08:57 PM
i dont think you can change the graph to a specific color of your choosing. i think it has a default sequence it goes through.
but just uncheck the log from the left hand side of VD and it'll display only the log(s) you have checked.
Old Jul 13, 2012, 03:14 PM
wizzo 8's Avatar
Ok cool that worked. Thanks
Old Aug 10, 2012, 12:15 PM
94AWDcoupe's Avatar
when will everyone start to use actual tire size when they use VD?????
https://www.evolutionm.net/forums/ev...-dyno-tip.html
Old Aug 12, 2012, 02:25 AM
el.guerrero's Avatar
ehi guys 1.19 come out!
Old Aug 14, 2012, 02:30 PM
charlie.tunah's Avatar
do you guys smooth afr and boost?
Old Aug 16, 2012, 07:58 AM
JorgeYaHeard's Avatar
Great thread fellas!
Old Aug 16, 2012, 08:14 AM
Kakihara's Avatar
In evoscan, the more parameters you log the less measure points per second you get and this as a huge influence on how much smoothing you can/must use
from my experience the less parameters you log the "smoother" the base curve is so the road is not the only reason for "spikes"
that said there's a limit at which you will get a lot of the same values in the same second because I guess the ECU and various sensors don't work that fast
I guess there must be a difference between Openport1.3 & 2.0 too since 2.0 is advertised as "slower logging"
it would be interesting to know the bare minimum parameters that Virtual dyno really requires to draw his curves, TPS and RPM ? so we can log only what's needed and nothing else
Old Aug 16, 2012, 08:47 AM
Raptord's Avatar
Yes, just TPS and RPM. It always has time since you can't uncheck that.
Old Aug 16, 2012, 09:00 AM
Boosted Tuning's Avatar
VD only uses one sample every 100rpm, regardless of how many samples the log has per second.
Quick Reply: How to use Virtual Dyno Properly
