Burping radiator please read
Ok, I just flushed my radiator with water hose I went through at least 3 cycles of shutting the car off n on each for about 10min , once with water hose and drain plug open, twice with both drain plug and radiator cap closed. (this is my first time doing this)
I need helping with burping the radiator, Im not sure if i did it right so here is what I did.
I topped off the radiator with coolant 50/50 no silicate,
Turned on the car and let it idle for 15minutes , while Idling I squeezed the upper and lower hoses a few times to get the bubbles out.
Everytime the fan went on, the coolant level would drop, once it went off it would start to rise again , It did this for about 15min finally I just closed the radiator cap, b/c it seems like this would go on forever.
What I want to know is if I did this right???? How long do I burp the radiator for? is 15min enough? should I have kept on doing it? what should I do now. Anything I missed please help me out here, I dont want air in my system and **** up my car!!!
sorry for the long post.
Nemui (Mar 20, 2016)
Run the car with the heater on. This will circulate coolant in the heater core also.
Check it in the morning. You'll probably find your coolant resevoir low. If there were air pockets in the system. it will vacuum the coolant in the reservoir. Just add up to the mid level.
You should be fine.
You should be fine.
Evoryder
Apr 29, 2019 10:09 AM
