Car sputters when cold?
I've been noticing my car sputtering and making zero power when it is cold.
At this time I am not in boost and at maybe 5-10% throttle. It usually goes something like this:
Start car, pull out of garage, roll down driveway in 1st gear, pull out on to the street. Give it some throttle to accelerate and when the car reaches ~1500 RPM it just stumbles and sputters. It sounds like the hi boost Evos that break up top on stock ignition, but obviously I'm at 0 boost and just above idle for RPM.
Due to this sputtering, I end up shifting to 2nd, where it sputters again for a few seconds. By this time, I've reached a stop sign at the end of my street. When I accelerate away from this stop sign, these symptoms are gone
It only happens the first 20-30 seconds of starting the car...it is a minor annoyance but I want to make sure I'm not damaging/have damaged something.
Not trying to jack your thread, but I have a very similar problem and some info to add.
First of all, I do let me car warm up, so that is not the issue. I can let it sit there for 5 minutes if I want and it will still do this same thing. It happens after the car has been sitting for an extended period of time (overnight or when I get in after work), but the rest of the time it's fine.
I have an XD-16 A/F gauge so I see what is happening, but I have no idea why...it goes extremely lean for those first 20-30 seconds of driving if you try to just give very light throttle...into the 18:1 A/F. I have to give it more gas than I want to just to keep it moving without "sputtering" and wanting to stall.
After about 30 seconds of driving this way, it is fine. Any ideas?
maybe i'm right about the forged pistons stock after all. in this article under performance. http://www.theautochannel.com/news/2...18/168969.html
The piston manufacturing process is really moot for this discussion because A) I doubt the pistons expand/contract enough to be causing a large enough blow by leakage for the sputtering we are experiencing, B) even if the expanding/contracting theory were true, there's no way it only takes 20-30 seconds for them to expand enough to stop this issue.
