Turbosmart evo 8 internal wastegate replacement upgrade
Hi everyone, has anyone on here installed a turbosmart internal wastegate that replaces the stock wastegate? what i want to know is, do you retain the factory hoses or replace hoses and use no restrictor pills. lets say i want to boost 22psi using this turbosmart internal wastegate, do i get a spring set up for 22psi and run boost source from j pipe to wastegate directly? or use the factory hoses that go to the factory boost solenoid?
Cheers
Max
Cheers
Max
canyonkid
Mar 9, 2017 10:36 AM
WTB[SouthEast]: Turbosmart 22 PSI Internal Wastegate Actuator
studioface
Aug 18, 2016 09:14 PM
LOVEMYX
Jun 24, 2016 06:37 AM
Jrod@Buschur
May 25, 2007 08:52 AM
