Stuck between the fp ss housing or the stock hosung
#31
The Red with MHI housing has great response and can make well over 400tq at low rpm IF you want it to. This was 30psi across and then 30psi up to 34psi. Took this to the track on my street tires and went 10.8@132 around 580 in the heat.
The SS green will not have this response or bottom end torque on a dyno jet.
#44
I went l19 just for extra peace of mind. And i got them at a great deal used.
I installed cams,springs,and head studs in one day with cylinder head still installed.
2 years now at 30 psi and ethanol no issues. Coolant level has not moved 1 inch and oil never burns.
Get the sequence for torquing head and do 1 stud at a time.
Remove old stud and then install arp and torque it to desired spec.
I also did a "retorque" 500 miles later for peace of mind, i was able to move 3 of the studs during the re torque.
DSMolition (Jan 17, 2017)
#45
@Abacus,
Is this a 3rd or 4th gear dyno pull?
