HEY SKUNK2, Should have listened to me. HOW TO MAKE YOUR TB WORK.
I'll look into both.
Thanks so much for the input. I was about to spend the same amount and send my stock one to get it ported. I woulda kicked myself in the butt. The price is basically the same bec I need to buy another tps if I was gonna get it ported and pay the shipping cost. Woohoo! So far it looks like the FB70mm is my best bet.
Tuned the iscv just fine, stock and on vipec. Also convenience of the set screw allowed acceptable tps <16% in idle circuit.
Max should be <15%.
Also, you can get the correct TPS sensor on Ebay factory part number, for 40~50 bucks.
Carry on.
Tommyfacekicker (Feb 23, 2017)
Which tps are you using? You said your tps is not within spec so you can get the correct tps on ebay. Maybe I just misunderstood your statement.
I'm prob gonna order my tb in a bit. Thanks for the input about the clamp breaking the tb. I seen that on the forums about them breaking. Ill look for a torque clamp also.
How do I start a thread? Can someone walk me thru the process. I'm having so many issues and I've been through just about every single thread that relates to my issue but none are exactly the same as mines. I wanna start a thread so I can specify my problems.
What is the set screw?
Cool thanks.
http://www.ebay.com/itm/181663376720...%3AMEBIDX%3AIT
Less than 16% is indicating 15% or less. I've been through the iscv thread countless times when I was using the stock ecu. Same thing different wording.
I'm curious about your set screw issue. I loved the fb way better than stock!
I had literally one of the First FB TB's. I'm trying now to remember if it has a set screw... Either way, car struggled with steps just like the Skunk 2. High steps result in more of the epic issue of rolling into a stop and idle dipping to the 750 range. Or like the clutch stall when parking drop to 750 low idles as well. This is an issue in setting the set screw correct. Could not do it with the FB. SO I sold it.
in this case on the fb 70 mm it sets base idle speed by cracking the blade slightly. T15(I think) torx with a jam nut.
Only the Works/Milspec/Stock Ported or even the Skunk 2, 68mm I have, actually seal. That's why I continued with it, even though it offers both options of a set screw, and a throttle stop adjuster.
