Front wheel wells
Old Sep 10, 2010, 10:17 PM
The hundreds.'s Avatar
Front wheel wells
My tires are rubbing against them after a drop, is it safe to remove the wheel well lining?
Thanks
Old Sep 10, 2010, 11:15 PM
DSMMR21's Avatar
i suggest rolling the fenders possibly?
Old Sep 10, 2010, 11:56 PM
flmr06's Avatar
what are you lowered on? theres a few selections that rolling the fenders is pretty much a must for it to work w/o rubbing
Old Sep 11, 2010, 12:02 AM
Stance LX+ coils
Old Sep 11, 2010, 12:04 AM
HaVoC187's Avatar
Leave it in and get you fenders rolled.
Old Sep 11, 2010, 12:07 AM
HaVoC187's Avatar
Or...since you are running coils,can't you raise the car a bit?Or do you really want to be this low?Pics?
Old Sep 11, 2010, 12:13 AM
yea... i think im going to have to raise it, it's just not practical, spanner wrench works on the stance right?
Old Sep 11, 2010, 03:35 AM
HaVoC187's Avatar
Yes.Just make sure you measure on each side so car sits level.
Old Sep 11, 2010, 05:02 AM
Bobster22388's Avatar
Not a real good idea to take them out, there's a lot of important wiring that runs behind there. Getting the fenders rolled is definitely the best way to go if you want to go low.
Old Sep 11, 2010, 09:49 AM
Even with rolled fenders, wouldn't it still rub the wheel well?
Old Sep 11, 2010, 01:59 PM
chaotichoax's Avatar
yeah rolling the fenders won't solve that...your best bet is to pull the wheels off and find out where it's been rubbing
heat up the plastic and try to reform it a little so it doesn't rub or just cut out the small sections it is rubbing in
have you had an alignment done? better camber and toe specs might help with rubbing as well...same goes for your wheel selection (offset plays a big roll)
regardless I'd raise the car a little to avoid the headache of rubbing holes in your fender liners
Old Sep 11, 2010, 02:14 PM
9evolution's Avatar
^ I had a lowered mustang that rubbed. I removed the wheel and cut the sections that were rubbing. I did try a heat gun but was not able to form it correctly
johnnys lancer
Aug 24, 2016 11:04 AM
QwikEVO
Apr 12, 2016 08:01 PM
FaceMe
Mar 16, 2016 02:01 AM
Splatzjackson
Mar 6, 2012 01:42 PM
blueevo3x
Jun 19, 2011 09:57 AM
Quick Reply: Front wheel wells
