Need some bright thinkers!
I thought my lug nut was stripped because I went to take it off and it just kept spinning. I came to find out it is the wheel stud and not the lug nut. It is not stripped it spins in the back behind the wheel hub. My problem is that I can not get it off. I tried hitting it in but it sits flush already I think the teeth of the wheel stud are stripped (hopefully not the hub). I also can get hand held vice grip on but the stud still spins when because they can get a good enough grip. I need some new ideas on how to get it off. I have about an inch or two of room to get to the back of the wheel stud. I am so frustrated I just want to get it off. I will probably take it to a mechanic tomorrow to see what they say.
Cliffs: Wheels stud spins can's get it off.
Just cut the wheel stud off and replace it. No use trying to seperate the two when they are most likely toast. Even if you have to remove hub with wheel attached. Try Yoqsaahoth's way first though, make sure the other lugs are properly tightened onto wheel before trying.
I will try with the wheel on the ground and how can I cut the stud I can't get the wheel off there is no way to cut it.
Edit still spins on the ground
Drilling it off may be your only bet (without ruining other parts).
It's going to suck, bad, lol. You only have to drill as far as the lug nut though. Make sure you get a good center-punch hole before you drill, and then start small, and work your way larger. Eventually, you'll drill through the threads holding the lug nut on, and it will come right off. With that done, you can work on replacing the stud, or the hub, depending on what stripped where.
now secondly im not sure if i understand you. the stud itself is spinning freely in the hub or the nut is spinning freely on the stud?
I have replaced a stud before it is probably the one that is giving me trouble. The stud is spinning freely in the hub the lug nut wont spin I need it to to get it off.
Ur using a impact right? Well lift the car into the air. Then remove the 4 good lugs. Then tilt the wheel. Like put it into a angle so it puts pressure on the stud, Then crack that Impact gun up and git r done. Not a guaranteed ting but try.
