help titanium exhaust
http://www.extremeturbosystems.com/E...st-System.html
I'm no expert on this but isn't maintaining gas velocity important as well, especially on a turbo charged engine?? In a perfect world you'd want an exhaust that creates minimum back pressure so it doesn't restrict the engine but keeps the gasses flowing as fast as possible. Having a huge exhaust would lower the gasses speed making you lose power generated by the turbine I believe
I am sure the math is all very complex and all, but the Bill Nye example would be put a banana in your tail pipe to increase back pressure and watch the power drop.
Remove the exhaust and add a dump tube and watch the power go up.
I agree back pressure is bad but high gas velocity is good, and to keep the velocity high there needs to be a certain amount of restriction in the exhaust. Like I said, I'm no expert but I think it's all about finding the right balance between keeping the backpressure as low as possible while keeping the gas velocity high. Keep in mind it's the exhaust gasses that spin up the turbo and it's not going to spin very fast if the gasses are barely moving.....
