HOW TO: modify your stock "lancer" gauge to accept useful gauges
Old Mar 26, 2007, 05:44 PM
trinydex's Avatar
How to modify your gauge cluster for a useful gauge.
Before:
After:
1. Take apart your dash and get to this point (gauges apart).
(image not found for the loss)
2. Fashion a circular base and cut out the shape of your wideband display.
This piece is glued in place so make it pretty. You can use a piece of plastic or whatever as well.
3. Use the base you made, and mark where you need to cut to fit your display. Your display will be different than mine. Deeper, shallower, wider whatever.
4. Cut the base. You may want to tape off the rest of the gauge assembly. Keep cutting until your display fits.
5. Depending on the thickness of the base you use, you'll need to shave a layer off the plastic. The cosmetic cover to the gauges actually sandwitches them.
So if your base is too thick, it won't fit. Think of this as shaving the frosting off a cake.
6. Glue the display to the base...You can use hot glue if you want. Whatever. Just attach it.
7. Run your wires through the open bulb openings in the gauge cluster
8. Position the base and display, glue the base into place.
9. Remove the bulbs from the back of the cluster
10. Place plastic covers back on
DONE
from: https://www.evolutionm.net/forums/sh...d.php?t=231113
trinydex is offline
Old Mar 29, 2007, 05:44 PM
LancerEvoMR's Avatar
Discuss thread HERE!
LancerEvoMR is offline
trinydex
40
May 31, 2016 01:56 PM
trinydex
Jun 30, 2014 02:26 AM
blkmkIII
May 9, 2010 11:54 AM
trinydex
Mar 29, 2007 05:45 PM
trinydex
Mar 24, 2007 12:24 PM
Quick Reply: HOW TO: modify your stock "lancer" gauge to accept useful gauges
