DIY plywood front splitter for Evo 8/9
Old Feb 7, 2016, 10:51 AM
  #76
killerpenguin21's Avatar
if you have a business you can ship to, go to harborsales.net
i think i paid $100 for a huge sheet of alumalite, cant remember if it was 4x8 or 4x10.
my splitter goes on/off in under 10 minutes, hardest part is getting the bumper on and off (i do have a bumper quick release). i have 6 attachment points, using the bolt holes for the front underbody brace bar, a cable on either side that hangs on a bolt into the frame near oil cooler on one side and acd pump on the other, and i have two hooks coming out of the bumper beam through the bumper. splitter has ability to have angle adjusted using plastic washers at the rear bolts and also has abaility to move up if hitting ground etc (which was happening until i upped my front spring rate)
the damn thing makes downforce tho...i have to replace the 3/8" hooks up front every 2-3 events due to bending...
Old Feb 12, 2016, 09:15 AM
  #77
codylop's Avatar
My plywood splitter.Will go with alumalite(6mm) later.As it sits I can get the car on and off the car trailer with the splitter on the car with added Race ramps (7ft.).
DIY plywood front splitter for Evo 8/9-forumrunner_20160212_110959.png
DIY plywood front splitter for Evo 8/9-forumrunner_20160212_111032.png
DIY plywood front splitter for Evo 8/9-forumrunner_20160212_111045.png
DIY plywood front splitter for Evo 8/9-forumrunner_20160212_111134.png
Old Feb 12, 2016, 01:00 PM
  #78
kaj
kaj's Avatar
If you can get that on a trailer, then driving through town shouldn't be too bad. Though I think mine may be closer to the ground. Hmmm.
Old Feb 12, 2016, 01:42 PM
  #79
I could carefully get on my trailer with a 5 inch splitter, but the way my ramps slide out I quickly caught an edge and ripped off a section of the splitter...I now just take the ten minutes to take it off.
Codylop - you should really think about adding an air dam, I think you are getting some decent spillage into the bumper imho
Old Feb 12, 2016, 02:03 PM
  #80
codylop's Avatar
The splitter it's right on the bumper (stock evo8 bumper). Car lowered 1/2in from stock. I plan on using adjustable inlinks soo I can get -3degs for autocross and track use.I don't drive the car in town, soo on and off trailer. I'm still adjusting the car but the splitter did help with understeer.It's nice to use plywood first as a mock up .My local sign business wanted 200$ for 6mm sheet of alumalite.If you mess up the plywood is 30$ but if you drill or cut the alumalite wrong you can be stuck with it.I know we can use cardboard but running plywood first let's you know if it's going to work .
Old Feb 12, 2016, 02:05 PM
  #81
kaj
kaj's Avatar
Yeah, attach/removal isn't too bad. But if I could leave it on...
And I still dont think it will fit in my car to get it to the track.
Old Feb 12, 2016, 02:13 PM
  #82
codylop's Avatar
Air dam and canards will be the next step.Looking like I will have to make canards.Thinking the apr ones or ones we can just buy will not work as great.It's harder to find ones for the Evo 8.Thanks
Old Feb 12, 2016, 02:40 PM
  #83
kaj
kaj's Avatar
Why are some people being charged so much for alumalite? Crazy
Old Feb 21, 2016, 03:41 PM
  #84
captinnitro's Avatar
Hey first let me begin by saying what a nice job you did. Having said that, for anyone else that want to try this a good alternative to plywood would be foam covered in Carbon & Aramid Hybrids fabric. and west system. http://www.shopmaninc.com/hybrids.html You could do hard points inlays for anchoring. In addition, it can be formed into any compound shape needed. I'll try to post a pic of a micro hydroplane a did just so you get the idea how you can shape the foam.
once covered and sanded the product is smooth as glass and strong as steel with about 1/2 the weight. sorry about the of off topic pic...
Old Feb 22, 2016, 05:13 AM
  #85
hispanicpanic's Avatar
exactly what kind of foam is that?
Old Feb 23, 2016, 09:52 AM
  #86
Extruded Polystyrene and it glues very strong with epoxy, so you can build up layers to achieve the desired height then sand away to obtain the desired shape. you can cut it with a knife, blade, jigsaw or better yet a hot wire. The trick is choosing the right fabric. to achieve proper straight. It will not warp and its weather resistant. people build kayaks and I have built r/c jets with this technic. very strong and lightweight. I would do hardpoint inlays for anchoring before laminating. It's really quite a simple job, the hard part is getting the shape right. I give EGbeater a lot of credit for his finish product. the pattern he used is perfect.
EGbeater (Nov 10, 2016)
Old Jun 2, 2016, 09:25 AM
  #87
Anyone know where I can find the stainless wire versions of the splitter support rods? I don't want anything restricting upward movement if I smash a kerb.
Old Jun 2, 2016, 10:34 AM
  #88
PAdutch's Avatar
I was concerned with this as well so I designed my threaded rod connections a little differently.
The top rod ends actually allow the threaded rod to slide up through the rod end. It's also convenient for loading onto trailers as I strap it up for clearance. I've only done some light road driving, as well as, 2 autox with this setup, but it seems to be working.
Old Jun 2, 2016, 08:04 PM
  #89
i used cable and crimp connections from home depot.
Attached Thumbnails DIY plywood front splitter for Evo 8/9-vir-front-end.jpg
Old Jun 3, 2016, 01:03 PM
  #90
Closeup pics?
Quick Reply: DIY plywood front splitter for Evo 8/9
