Brembo Brake Rotors, Brembo Big Brake Kits, Axxis & Hawk Pads, Goodridge SS Lines
Hey folks! We are a new vendor here on EvolutionM. We have been around on other forums for years now, but have just now discovered EvolutionM. I think you'll find these to be great deals that will be tough to beat. Feel free to call, e-mail, PM, or post (contact info below) with any questions you might have. Otherwise, thanks again for checking us out, and enjoy!
Brembo Brake Rotors - Crossdrilled or Slotted
Brembo is the leader in the design, development and production of Original Equipment, racing and aftermarket brake rotors. We guarantee that you will not find theses Brembo rotors anywhere near these prices!
Here are some of the benefits of using a Brembo Rotor:
HIGH CARBON DISCS
Brembo brake rotors are high carbon discs, and have the ability to better dampen vibration and noise, thus improving comfort and performance.
PILLAR VENTING
Pillar Venting allows more even cooling of the rotor which eliminates "hot spots" on the braking surface. Which will help prevent warping and fading.
COMPUTERIZED (ELECTRONIC) MILL BALANCING
Mill Balancing ensures precise balancing of the rotor, and helps prevent warping and performance loss. This also makes the rotors much safer.
CERTIFICATIONS
QS 9000 Certified, ISO 9001 Certified, ISO 1400 Certified, and TUV Certified
GOLD ZINC PLATING
The drilled or slotted rotors are coated by Brembo in a zinc/cadmium plating to help prevent rust and ensure rotor longevity.
All of these rotors are GENUINE Brembo Rotors. The drilled or slotted we sell are cast-in by Brembo at the time of manufacturing. Do not be fooled by companies that purchase Brembo plain OE replacement discs and have them altered by a third party. These misrepresentations usually are offered as a cross drilled and slotted disc which Brembo does not produce. If you contact Brembo, they will not recognize these discs after they have been altered. If you want a drilled or slotted Brembo, get these authentic ones.
Here are some pics of the Drilled, as well as the Slotted:
Brembo Rotors prices: (Prices are PER PAIR)
2003 - 2006 Mitsubishi Lancer Evolution
Crossdrilled: --- Front: PN FD00103 (35622) $355.00
--- Rear: PN RD00061 (35632) $335.00
--- Full Set of F & R: $680.00
Slotted: --- Front: PN FS00103 (45622) $355.00
--- Rear: PN RS00061 (45632) $335.00
2002 - 2006 Mitsubishi Lancer Sedan LS & OZ Edition (Rear Drum)
Solid Faced: --- Front: PN 25364 $64.00
Crossdrilled: --- Front: PN 35364 $139.00
Slotted: --- Front: PN 45364 $139.00
HAWK HPS & HP Plus Brake Pads
HPS - High Performance Street disc brake pads are world renowned for increasing stopping power on your street legal vehicle. Increasing the performance of your vehicles braking system is easy when you choose Hawk Performance’s HPS braking compound. This unique Ferro-Carbon formula was developed for street performance using the safety and quality of Aerospace and Motorsports severe-duty friction technology. The High Performance Street compound offers a higher coefficient of friction over stock brake pads and can provide you 20-40% more stopping power and higher resistance to brake fade than most standard replacement pads. Less fade means you’ll have a highly durable brake pad with less brake dust.
HP Plus / Autocross - Hawk Performance’s HP Plus brake pad compound is ideal for Autocross and Track Day drivers looking for a high performance race compound that can take the heat of the track and get you home safely without having to change the pads. HP Plus utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and “track day” applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials. Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
Hawk Pad Prices: (Prices are for full set)
Hawk HPS: --- Front: PN HB453F585 - $100.00
--- Rear: PN HB180F560 - $65.00
Hawk HP Plus: --- Front: PN HB453N585 - $135.00
--- Rear: PN HB180N560 - $95.00
Hawk HPS: --- Front: PN HB438F606 - $65.00
2002 - 2006 Mitsubishi Lancer ES Model (Rear Disc)
Hawk HPS: --- Front: PN HB435F622 - $75.00
--- Rear: PN HB457F605 - $60.00
PBR/Axxis Brake Pads - Ultimate (Ceramic/Kevlar), Metal Master (Semi-met), Deluxe Plus (Organic/Ceramic)
Note: The FMP Group Australia Pty. Ltd., is the manufacturer of Axxis and PBR brand brake pads; these pads are identical.
The PBR Axxis Ultimate brake pads feature a special Kevlar® and ceramic-strengthened formula with a high co-efficient of friction and excellent high temperature wear and fade resistance. Designed for ultra-high performance driving and hard-braking applications, PBR Axxis Ultimate pad users will benefit with extreme stopping power and high resistance to brake fade at high temperatures, meaning the decrease in friction over repeated heavy duty stops, as the temperature increases, is minimal. PBR Axxis Ultimate pads boast a maximum continuous working temperature of 550° C (1022° F degrees). Consistent throughout its operating temperature range, you’ll get dependable, predictable stops time after time while maintaining a solid pedal feel.
The PBR Axxis Metal Master pads are made from a Non-asbestos, semi-metallic compound that provides the highest fade resistance among leading semi-met brake pads. They deliver proven longer pad and rotor life, with low rotor scoring and quiet braking. They are made with a unique formula that offers reduced brake dust, fade and squeal. These are the longest lasting brake pad on the market!
The PBR Axxis Deluxe Plus brake pads offer an exclusive OE equivalent organic and mild ceramic compound that provides outstanding stopping power with very low fade. Extremely quiet with proven long pad and rotor life and low rotor scoring. These pads are formulated from the latest premium quality materials, and are known for their extremely low dust. The Deluxe Plus brake pads will virtually elminate brake dust, without hurting performance.
PBR/Axxis Prices: (Prices are for full set)
Ultimate: --- Front: PN D 1001 RU - NYA
--- Rear: PN D 961 RU $48.00
Metal Master XBG: --- Front: PN D 1001 RM - NYA
--- Rear: PN D 961 RM $41.00
Deluxe Plus: --- Front: PN D 1001 R - NYA
--- Rear: PN D 961 R $35.00
Ultimate: --- Front: PN D 1455 RU $48
Metal Master XBG: --- Front: PN D 1455 RM $39
Deluxe Plus: --- Front: PN D 1455 R $34
Ultimate: --- Front: PN D 866 RU $48
Metal Master XBG: --- Front: PN D 866 RM $39
Deluxe Plus: --- Front: PN D 866 R $34
Brembo Gran Turismo Big Brake Kits
Hey guys - this is it - if you want the BEST brakes money can buy, these are them right here! The Gran Turismo system’s level of technology and performance is unrivaled by any other product on the market. Each system is designed vehicle specific for maximum performance and “Optimum Brake Balance”. Gran Turismo Systems are comprised of lightweight 4, 6 or 8 piston calipers and 1 piece or 2 piece “floating” vented rotors up to 15” in diameter. Calipers are available in red, silver, gold, or black and discs are available in cross drilled or slotted. The system also comes with brake pads, stainless steel brakelines and all the required mounting hardware.
High Performance Friction Material:
Aggressive pads that provide the highest level of performance.
Cross-Drilled or Slotted Discs:
Clears gasses, cleans pads for better bite.
Mounting Brackets and Assembly Hardware:
Aircraft quality included and pre-torqued specifications.
Goodridge Stainless Steel Braided Brake Line:
DOT/TÜV approved.
Multi-Use Street, Performance Driving, Track Events Derived from Race-Based Components:
Increased stopping on the street, at drivers' schools and at club events with proven on-track performance at the highest levels of racing.
Floating Disc Mounting System with Billet Aluminum Hat:
Reduce Unsprung Weight for better handling and reduces heat-related stress; increases brake performance and pedal feel.
Four or Eight Piston Cast Aluminum Calipers:
Provide maximum braking force without the flex of sliding calipers.
Here is a sample picture of a kit with silver calipers:
Here is a sample picture of a kit with red calipers:
Here is a sample picture of a kit with blackcalipers:
These kits are available in all 3 caliper colors (except for the smaller kits that come in gold). Also, the You also have a choice between drilled or slotted rotors.
Now for the prices....(Prices are for the ENTIRE kit)
FRONT FITMENT
355x32 2-Piece Rotors
4 Piston Calipers
Rotors: Choice of DRILLED or SLOTTED
Calipers: Choice of SILVER, RED, OR BLACK
Part number: 1B2.8038
EvolutionM Member Price: $2850.00 w/ FREE SHIPPING
REAR FITMENT
328x28 2-Piece Rotors
4 Piston Calipers
Part number: 1A1.6010
EvolutionM Member Price: $2250.00 w/ FREE SHIPPING
Goodridge G-stop Stainless Steel Brakelines
We have these Goodridge lines in stock, and I figured it would be good to sell them with the pads and rotors we have on here. This should be the best deal you can find on these lines from anywhere. Please e-mail, PM, or call us if you have any questions about anything regarding this post. Thanks for checking this out!
Brakeline Prices:
Part number: 26052
Price: $99.00
Part number: 26049
Price: $109.00
ATE Super Blue Brake Fluid
-This high performance Brake Fluid is ideal for coping with the extreme demands posed by motor racing, autocross, or high performance driving.
-Exceeds all DOT 4 requirements
-Dry boiling point 536 deg. F, wet boiling point 396 deg. F
-This fluid is NOT SILICONE and is compatible with conventional brake fluid.
-The blue color lets you know when to stop bleeding the brakes, showing the blue when all your old fluid has been bled out.
1 liter - High Performance Brake Fluid
Part number: 03.9901-6302.2
Price: $12.50 per liter
-How To Order-
We accept Visa, Mastercard, American Express, Diners Club, Discover, and JCB
Online -
Go to our website, CLICK HERE and add the parts you want to your cart. When checking out your order in the "Notes" section type in "EvolutionM DISCOUNT" and we'll edit the order total after you place it and you'll be charged the correct sale amount!
Phone Orders -
Give us a call at 425-357-6818. We're open all day Monday-Friday to take your orders over the phone!
Paypal -
Give us a call or E-mail us for your total price including shipping. We base the shipping based on your zipcode and the weight of the package. Charging exact shipping and not padding it into the price, allows us to offer the lowest possible price. All Paypal payments must be sent to: paypal@importrp.com
Money Order/Cashiers Check -
Contact us for details on payment this way. E-mail us at: sales@importrp.com
Have a Question? E-mail us at: sales@importrp.com or call at 425-357-6818. We're open Monday-Friday from 8 am till 5 pm and answer emails 7 days a week.
Thanks for all your support, we GREATLY appreciate it!!
Best Regards,
Jeff
Brembo Brake Rotors
Axxis Brake Pads
Goodridge Brakelines
Hawk Brake Pads
HIGH CARBON DISCS
PILLAR VENTING
CERTIFICATIONS
GOLD ZINC PLATING
DOT/TÜV approved.
FRONT FITMENT
4 Piston Calipers
REAR FITMENT
4 Piston Calipers
Brakeline Prices:
Part number: 26052
Price: $99.00
Part number: 26049
Price: $109.00
-How To Order-
Online -
Phone Orders -
Paypal -
Best Regards,
Jeff
Brembo Brake Rotors
Axxis Brake Pads
Hawk Brake Pads
Originally Posted by Mr. SUAVE
how much for the set of drilled brembo rotors F/R and ATE brake fluids? how much fluid will i need? pm price shippped to 19149
any actual pics of the drilled rotors?
Just pm'ed you. Thanks!
importdps
Evo 'For Sale' Suspension / Brakes / Handling
134
Mar 4, 2010 12:55 PM
Gruppe-S
39
Feb 26, 2008 10:51 AM
importrp
Aug 18, 2006 05:24 PM
Speed Element
Aug 16, 2006 01:10 PM
Speed Element
Jan 10, 2006 04:57 PM
