Gutted and Blacked Out Trunk
While at GSC getting my clutch, springs and motor mount done I decided to gut the trunk. I didnt like the plain white sheet metal look, so I changed it up. 3 cans or undercoating later.....viola!!!!!
Still have a few spots I got to hit up tommorow.
Originally Posted by WhatNoise???
Crazy! I prefer the raw look of it being unpainted. It saves weight!
Originally Posted by BADEVO
3 cans of undercoating weigh less then them 2 cheesburgers you had for lunch. bwhahahahaha
Don't think you should have painted the windshield washer reservoir, can't see the fluid level now. You should have at least taped off the wiring harness and other bits, lots of overspray looks bad. I also think you should have used paint instead of undercoating, it weighs less and will not get undercoating all over anything you put in your trunk now. Throw some luggage back there and you will be pissed. The trunk is not an undercoat neccessary environment. I do like that you took the time to do this though, and to post the pictures...
