Old Nov 12, 2012 | 07:26 PM
  #6721
TougeGod7's Avatar
would a 245/45-18 pirelli slick on a 18x10 work, or is the sidewall too tall and will cause lots of problems?
Old Nov 12, 2012 | 09:09 PM
  #6722
Evolution IVGSR's Avatar
Tires will be stretched slightly on that wide of a wheel and 245/45/18 is going to be about 1.6-2" taller than the stock size so that is a pretty tall tire to go with. A more ideal tire size for an Evo 8 or 9 and a 18x10 wheel for race slicks would be a 265/35/18. This is about the same height as stock and is recommended for a 9.5-10" wide wheel.
Old Nov 13, 2012 | 07:07 AM
  #6723
goad_white03's Avatar
18x11 CCW LM20s with 295/30/18 R888s. More to come!
Old Nov 13, 2012 | 07:25 AM
  #6724
Evo Tengoku's Avatar
CCWs FTW!
Old Nov 13, 2012 | 04:12 PM
  #6725
TougeGod7's Avatar
thats what i thought there's an unused set at my work that i could basically get for free but if its that much taller there is no way it will work on my car
Old Nov 14, 2012 | 12:52 AM
  #6726
Understandable when you find a good deal. You just want to jump on it Ya I have collected over the years and have quite a few tires. I get mine for pretty good prices since I jump on the deals when I hear or see them locally. Helps that there is a race track not far away from where I live and work
I have the 245's for my 9" wide wheels and then some 285's will be for my 10.5" wheels later down the road after some body modification
Old Nov 14, 2012 | 06:51 PM
  #6727
TougeGod7's Avatar
i have a set of nt03s that are 9.5" wide that i could put them on but i'd still wouldn't be able to clear them seeing how tall they would end up being
what rims you going with to fit the 285s? i have my 285 R6s on my 18x10 +38 RPF1s. i would like to put a bigger rim under there if i could, but without modifying the body or getting CCWs and aftermarket trailing arms i don't think its possible
Old Nov 14, 2012 | 11:05 PM
  #6728
I had a set of 18x10.5 +15 RPF1's on my last Evo so I was going to go with that again for cheap light weight race wheels. I want to go wider, but that will more than likely require 3 piece wheels like CCW's.
If I can work a deal out with a friend I would love to pick up one of his 18x11 TE37 sets
I am actually going to be running 245 and 255 wide tires on some 18x9.5 I have now
Old Nov 18, 2012 | 01:33 PM
  #6729
Justin Fox's Avatar
Cheers to the SB boys.
Old Nov 18, 2012 | 01:52 PM
  #6730
NavDan's Avatar
^^^ THIS is neat! Simple, clean yet ultra aggressive. Nice one Justin
Old Nov 19, 2012 | 04:47 PM
  #6731
ApexEVoIX03's Avatar
Work Cr Kai 18.9.5 +20 w/ nitto 555's 265/35/18
Old Nov 19, 2012 | 07:02 PM
  #6732
asu11's Avatar
^ Alot of fender work?
Old Nov 19, 2012 | 07:09 PM
  #6733
whiteEvo08Y's Avatar
Those are some crazy wheel/tires setups
Cant wait till i order a set for my car.
Old Nov 19, 2012 | 08:42 PM
  #6734
JdmGraphiteMR's Avatar
LOVE the new wheels goad_white!
Old Nov 20, 2012 | 12:12 AM
  #6735
just rolled the rears and the fronts now have evodave fender mod.. they rub in the rear over big bumps. Tires are a little too big along with too low of an offset lol
