The Official Wide Tire Thread
Old Mar 1, 2012, 06:49 AM
  #166
Evo8RA's Avatar
Originally Posted by PAdutch
Thats a crazy set-up. Not sure how you kept them from rubbing. Also I guess they cleared the brembo's. Pretty cool none the less.
Actually, I'm running the AMS Wilwood drag race brake kit and stiff springs to clear the wheels/tires. They work great for my autocross need.
Old Mar 2, 2012, 06:21 AM
  #167
nollij's Avatar
What are you all running to get your rear camber?
Old Mar 2, 2012, 07:45 AM
  #168
R/TErnie's Avatar
Are you asking what tire size and compound?
Hoosier R6 285
Old Mar 2, 2012, 10:05 AM
  #169
nollij's Avatar
No, are you using larger eccentric bolts or adjustable control arms to get your rear camber past -1.5 without changing the toe? Or are you using toe control arms?
Old Mar 2, 2012, 10:31 AM
  #170
Evo8RA's Avatar
At one time I was running -2.4 rear camber and used Agency Power adjustable control arms to do it.
Old Mar 2, 2012, 10:57 AM
  #171
nollij's Avatar
I am probably going to be aiming for around -2.0 rear camber with 0 toe but I am not sure whether the megan adjustable toe rod or the Agency Power adjustable control arms are the answer. The Agency Power adjustable control arms do not seem to be able to cure the toe in with higher camber.
Old Mar 2, 2012, 12:59 PM
  #172
R/TErnie's Avatar
I just used the whiteline eccentrics.
Old Mar 2, 2012, 02:06 PM
  #173
griceiv's Avatar
neither, just lower the car more and you'll have a ton of negative camber.
Old Mar 5, 2012, 11:18 AM
  #174
nollij's Avatar
My current plan is to run near stock height in the rear and just lower the front a bit to increase the rake.
Also, I just bought the Megan Adjustable Tie Rod arms. I will probably end up having to play around with this for a while to get what I want out of it.
Old Mar 5, 2012, 05:00 PM
  #175
RJones's Avatar
My car isn't slammed, and I was able to get around 2.7 degrees of negative camber and zero toe in the rear. This was with about a 2 finger gap and 285/30/18 Hoosiers.
Old Mar 5, 2012, 05:03 PM
  #176
griceiv's Avatar
well maybe your plan is wrong?
Old Mar 7, 2012, 09:52 AM
  #177
Received 1,384 Likes on 1,317 Posts
LOL^^^
I did the same years ago (noob move) by running only the front lowering springs & stock rears. Realized how scary the EVO was when cornering (Oversteer
Take our advice & run the proper springs & proper rake
Old Mar 7, 2012, 07:29 PM
  #178
nollij's Avatar
I am running Bilstein PSS9s. Not lowering springs. Not like I can't play with things around until I get the response I want.
Also, not running slicks. Just 285/30/18 Yoko Advan AD08s.
Old Mar 7, 2012, 09:03 PM
  #179
TougeGod7's Avatar
+1 but I have about a 1 finger gap in the rear
Old Mar 17, 2012, 07:42 PM
  #180
JDavenport's Avatar
Anybody tried PF01's in the 18" sizes?
Quick Reply: The Official Wide Tire Thread
