Clunking front end noise??
Old Feb 12, 2014, 02:12 PM
  #736
vmrevo9's Avatar
I have heard this on my friends evo 8 and recently with my ix. Both times it ended up being the 17mm nut that secures the strut piston to the top hat. On my friends car it was loose, once we tightened it the noise went away
On my it started after i replaced my shocks and i had to play around with how tight i got the nut. Too tight made the popping noise worst. I pretty much tightened it as much as possible then loosened it about 2 turns and the noise has gone away for now
Does anyone know the specific torque value for that nut?
Old Feb 20, 2014, 09:11 AM
  #737
cerevo's Avatar
^^ would the top at being loose or worn out cause a toe out scenario?
My car seems to all of a sudden gotten toed out really bad. When I'm driving on the interstate and hit a bump like going over a bridge, the car will jump to one side or the other.
Also after hitting at high speed bump its like the front right wheel is bouncing up and down for a little bit after the bump, the left wheel does not do this and its out of nowhere that this started happening.
Old Feb 26, 2014, 11:08 PM
  #738
SloG63's Avatar
I just had this, the top strut mount came loose when I went over a pot hole and it kept making a clunking noise.
Tightened it back up and it was gone but I had to replace my front drivers side coilover b/c it was blown during the incident
Old Feb 27, 2014, 03:22 AM
  #739
cmross13's Avatar
Originally Posted by cmross13
New strut bearings/top hats from RCHill for $108 fixed my clunking problem. Still needs struts tho, they have gotten weak over 110k miles lol
blew the strut. got a set of F&R Bilsteins from tirerack for $800 shipped. awaiting delivery now
Old Feb 27, 2014, 06:52 AM
  #740
fugiwara's Avatar
Good deal you got, is it the yellow MR Bilsteins you got?
Old Feb 27, 2014, 07:19 AM
  #741
cmross13's Avatar
Bilstein B6(HD)
Front # 35-118435
Rear # 24-118446
They are NOT OEM MR pieces, which run about $2100/set, but yes, lol, they are yellow.
Old Feb 27, 2014, 08:32 AM
  #742
fugiwara's Avatar
Question
Bilstein B6(HD)
Front # 35-118435
Rear # 24-118446
Thanks for the info!
Also, when you had the clunk sound, does it also happen when you turn the wheel trying to get in and out of a parking space?
Old Feb 28, 2014, 07:03 AM
  #743
cerevo's Avatar
I got a socket on the top nut of the strut but when I turned it it was turning the whole inner rod and spring. Not sure how people are getting that to turn. looks like it needs some special tool to hold the middle piece while turning the nut with some other special tool..
Old Feb 28, 2014, 02:29 PM
  #744
Tscott's Avatar
I have the same problem. I was messing with my tie rods and they were the only thing I could get to make that noise
Old Mar 1, 2014, 04:56 AM
  #745
vmrevo9's Avatar
Update on my setup; I had to reseat the springs. And reposition the top hat. Problem solved
Old Mar 1, 2014, 06:14 PM
  #746
fugiwara's Avatar
thanks for the update.
Here is what I found with my car, the sway bar endlink bracket was loose, when I tighten the two bolts attached to the control arm, the bolts were seized. I drilled out the old bolts replaced with new ones.
Old May 18, 2014, 07:34 AM
  #747
redline38's Avatar
Replaced Front strut mounts in my 2011 MR 2 days ago and it appears the noise (which had gotten horrible over last year) is gone. It usually got really bad on warmer days so I'll keep results posted.
Took 2 hours to replace. Top bolts were a PITA. Had to throw struts back on the car, dropped off stands and used impact to break free. OEM strut mount bearings suck and I'll probably have to replace again in another year but definitely worth doing.
60$ a piece from mitsubishipartswarehouse.com
part# 4060A134
Old May 20, 2014, 08:51 PM
  #748
Puckhead's Avatar
Just had the noise myself in the RH front area. Checked the top nut on the strut, it was finger tight. Re torqued it, all good now. Also checked the LH side and got about a half a turn out of it. I have 05 MR Bilsteins with WORKS ride springs that have been in the car for about seven years now and this is the first sign of trouble. Now I know what to look for, really glad it was simple. Thanks to everyone for all the input.
Old Jul 2, 2015, 04:51 AM
  #749
Dirtrider741's Avatar
Mine only clunks when it is cold out but I'm going to check the strut tower nuts tonight to see if they are loose
Old Aug 9, 2016, 07:53 PM
  #750
kyoo's Avatar
tapping this thread for suggestions - https://www.evolutionm.net/forums/ev...inks-help.html
noise started after clutch job & fsb swap - not the endlinks, tried driving with the fsb totally disconnected - can feel the popping through the pedals & floor. subframe was lowered slightly to make space for the clutch job, and I have a feeling something's still not aligned correctly there. any other ideas greatly appreciated
Quick Reply: Clunking front end noise??
