Comp speakers ,amps & subs
Old Oct 23, 2010, 06:53 AM
morfhious3's Avatar
to those who had experience of the ff: choices of COMP SPEAKERS, AMPS & SUBS,need your opinion and the reason why you picked that brand and model.for i never had these.for the budget, here are the ff.
COMP SPEAKERS ----$300
AMPS-------------------$400
SUBS-------------------$300
I HAVE THE KENWOOD EXCELON DNX 9140 as my head unit.and i wanted to use my factory box for the sub.I LISTEN TO ALL KIND OF MUSIC. so here are my choices based on my budget and read on the forums.
COMP SPEAKERS:
JL C5-650 --------------------$300
DIAMON HEX S600S---------$250
FOCAL 165V1 POLYGLASS--$299
MOREL DOTECH OVATION--$350
AMPS:
JL HD 600/4----$399
ALPINE PDX5---$299
SUBS:
IDQ 10V3D4-------$259
JL 10 W6V2D4----$269
JL 10 W3V3-------$155
NEED YOUR ADVICE AND EXPERTISE ON THESE.IF YOU HAVE ANY OTHER BRAND/ MODELS IN MIND TO SUGGEST PLEASE PUT IT IN. THANKS IN ADVANCE FOR THE INPUT.
Old Oct 23, 2010, 07:21 AM
FJF
FJF's Avatar
You may want to consider an IDQ10V2D2 - higher sensitivity, more flexible enclosure requirements, and lower current draw. Woofersetc.com may still have some in stock. I'd also suggest staying away from a PDX5 due to its (random) noise issues. Good luck.
Old Oct 24, 2010, 02:14 AM
morfhious3's Avatar
Anymore opinion?common guys need your input....
Old Oct 24, 2010, 08:25 AM
inuviii's Avatar
You may want to consider Boston Acoustics, too. Very clean sound. I ran them in my old Impala SS and I'm running them now, although there isn't any real base to speak of, so you'll probably still want that sub.
Old Oct 24, 2010, 10:17 AM
EvoM Community Team
migs647's Avatar
I do NOT like focal. I think they are overpriced for the performance they give off. I have yet to be wowed by their car audio or their home audio solutions.
I do like CDT Audio though. Really crisp, clean sound. They give have that "crack" sound. No distortion what so ever. You can get a good set from woofersetc for fairly cheap since they carry last years models.
I am currently running Exile XT65 components. These are great components, have great mid bass, and the tweeters scream when set up with +3db on the crossovers.
For rears I'm running Exile SX65c. These co-axials are great! No complaints there.
As far as amp(s), I believe in our heavy cars, just running 1 amp is good enough. My vote goes for JL Audio XD700. I have a G6600, and it is more than enough for my JL Audio W3 10", and powers my Exile speakers. I was running this same amp on my CDT set up in my VIII, made them purr.
BTW, I am running a Kenwood 9140 as well.
Old Oct 25, 2010, 09:20 AM
morfhious3's Avatar
thanks guys.hey migs,i was reading your post on the exile forum too...lol...where did you buy them and how much?
Old Oct 25, 2010, 09:44 AM
EvoM Community Team
migs647's Avatar
I got my XT65s directly from Bill at Exile. I got my XPe65s & SC65cs from Sounds Unlimited in McMinnville, OR. My XP65s were $250 and the XT65s were $325, well worth the extra $75. Was a special deal since I wasn't liking the XPe65s. I'm sure you could talk them down though
Old Oct 25, 2010, 09:51 AM
morfhious3's Avatar
thank migs.i'll try call them.hows the g6600 handling those speakers and sub?i'm seeing $300 for that amp right now.worth the money or should go for more $ for the xd 700?
Old Oct 25, 2010, 10:19 AM
EvoM Community Team
migs647's Avatar
The amp is handling everything just fine! It's a great system, no distortion, no complaints. If size is an issue, get the xd700, otherwise the g6600 will do just fine.
Old Oct 27, 2010, 12:25 AM
FernandosEvo's Avatar
I will sell you my almost new 6 1/2 kicker Q's!!! i have two sets and i will sell them to you for 650.00 for both. they run about 550 new. Pm me
Old Oct 27, 2010, 03:42 AM
morfhious3's Avatar
thanks.i found the one ive been longing for...im going for hertz mlk...
Old Oct 27, 2010, 01:02 PM
njevoxpb's Avatar
I have a full Hertz/Audisson set up in my truck and I love the sound. These speakers like power and the more you put through them, they will open up more. The Mille speakers will need a quality amp to bring the best out of them. My Mille 10 inch sub is powered my an Audisson mono amp, so if you're going Mille throughout your car, do not skimp on the power side of things...I also use a 5 farad cap and I've never had any issues with alternators or batteries or anything in my truck and I'm using the OE battery (yes, I should spring for a yellow top soon). The size of the amps will be an issue in the Evo with the limited trunk space. You could eliminate the spare tire and you would have no problem...a can of fix-a-flat and mini air compressor will get you going faster anyways.
Hertz makes really nice speakers and I've mixed and matched mine due to depth issues, so I have a mix of their Mille and Hi Energy lines (components in front with 6x9 in the front doors and 6inch in the back) again it will depend on the depth of these Evo x doors.
I'm already planning out the removal of the Rockford stuff and maybe going with Hertz/Audisson again on my X.
Old Oct 27, 2010, 08:55 PM
morfhious3's Avatar
thanks njevoxpb.im just going with hertz mlk 165 comp for the front and leave stock the back.running the jl hd 600/5 or the 900/5 for the speakers and the 10' jl w3.i want to use my stock sub box?any suggestions?what do you think of the morel dotech ovation 6 comp speakers?
Old Oct 27, 2010, 09:46 PM
EvoM Community Team
migs647's Avatar
I used my factory sub box. I had to take it out, cut a hole in the back and re-glass it so there was enough room for my aftermarket sub.
Old Oct 28, 2010, 03:49 AM
morfhious3's Avatar
migs,i was looking on that jl xd 600, no 700.they rated same as your g 6600 but the xd is a little bit more smaller in size compared to the g's.iwas wondering though if it could power enough the hertz mlk165, factory rear speakers and jlw3 subs.i think hertz is rated at 150 rms. peak is 300.im going over the budget for comps speakers so i could done it right for the first time.
Quick Reply: Comp speakers ,amps & subs
