I want to quiet down my Evo - any advice welcome
Old Nov 26, 2014, 05:52 AM
nala's Avatar
I purchased my latest Evo with the following mods listed below already installed.
While the car is fun to drive, the sound is getting to be annoying. It's not that it's super loud, because it's not, but the resonance is getting to me - like a constant "thrumming" or drone or a really loud vacuum cleaner, particularly when letting off the throttle. Any suggestions for quieting this thing down or changing the tone so that it's not a constant noise, but without sacrificing much (if any) power?
Buschur Crossflow
Buschur UICP and LICP
Buschur Intake
AMS FMIC
Old Nov 26, 2014, 08:57 AM
hoobastnk90's Avatar
Change the exhaust out for stock or a different type of exhaust. Otherwise this really isnt the most quiet car..
Old Nov 26, 2014, 09:07 AM
ak47po's Avatar
You bought the wrong car.
Old Nov 26, 2014, 09:21 AM
ETS Michael's Avatar
You could add a large resonator or a second muffler in line. That would help.
Old Nov 26, 2014, 11:05 AM
spyderx's Avatar
Stock X is quiet when I got my new 14 MR.
You'll want to add a cat, quiet cat back. That should make a big difference.
I have stock cat and Magnaflow dual tipped cat back (made by Magnaflow) - really quiet.
Sometimes I think it's too quiet.
Old Nov 26, 2014, 11:59 AM
nala's Avatar
Thanks. My 2008 was quiet with stock exhaust. As noted, this one is not loud, just "droney". I didn't know if adding a mini muffler or resonator would do the trick, but hopeful that it will.
Old Nov 26, 2014, 03:00 PM
We have an exhaust system available with a larger muffler (similar to stock) but, with full 3.0" piping.
http://www.extremeturbosystems.com
Michael
Old Nov 26, 2014, 10:15 PM
deanob's Avatar
I wanted the same thing and went with a Q300 which is large muffler + resonator, then I got a TP with a resonator too. The ETS version should be just as good tho.
Quiet at idle and part throttle but really opens up at WOT, sounds great.
But my MR has tons of sound deadening so I'm told it's still pretty loud lol.
Old Nov 26, 2014, 10:45 PM
Locke's Avatar
Couple of notes...
I need a better understanding of your definition of quiet...
Some basic suggestions. Go wit a stock O2 housing and a 3" DP. Use a high flow cat. That section should also be 3" inches throughout. From there you have options.....
1. Get a USA made 3" quiet exhaust. ETS and COBB both make one. ETS has a Quiet Exhaust for a screaming deal....ask Mike at ETS. Cobb's is also mandrel bent in house using overseas steel.
2. Get a 2.75" exhaust. The Tanabe is very quiet. Rule of thumb, the horizontal, to exhaust flow. Equal ports flow a bit more compromised at higher(400) horsepower but, they are much quieter compared to the round straight through muffler/resonaters.
The full 3" will flow more efficiently, even better catless, however it will be louder, smell worse, higher SOX and NOX, etc...depending on company and muffler design
Good luck and happy shopping.
p.s.... this is what insomnia does, damn forums...lol
Old Nov 28, 2014, 06:52 PM
kyoo's Avatar
i put a second muffler where the cat goes, that helped
Old Nov 28, 2014, 07:38 PM
TwStDeVo's Avatar
might want to look into this, I have the one they make for the evo 8/9 and it made a big difference in sound.
http://www.streettunedmotorsports.co..._race_pipe.htm
Old Dec 10, 2014, 09:52 AM
Awilliams2232's Avatar
My friend has a full turbo back exhaust. Very loud car until he changed his test pipe to a resonated. Silenced it quite a bit. Def is quieter next to mine!
Old Dec 10, 2014, 08:45 PM
Imprezme's Avatar
add a resonator
Old Dec 11, 2014, 09:04 AM
Ev0ikon's Avatar
Yay for resonated testpipe!
Old Dec 12, 2014, 09:41 AM
STM Tuned's Avatar
Check out our STM ultra quiet resonator, Quiets down the exhaust quite a bit.
http://www.streettunedmotorsports.co..._resonator.htm
Feel to give me a call at 585-226-8226
-Ethan
Quick Reply: I want to quiet down my Evo - any advice welcome
