Stock frame turbo options these days?
What are our options these days for a good reliable stock frame turbo upgrade? I'd rather not have to send out my stock turbo to be upgraded, but if that's the only option then so be it. Looking to make over 400, even up to 450 on 91 pump. I see bad reviews on the Garretts and not even sure if the BBX is being produced any longer, or if FP is still in the game and their quality is what it used to be. I'd rather have BB over JB if possible. So what's out there these days?
Thanks guys!
Thanks guys!
Fp Black should work. I'm making 425 on pump gas at the wheels with bolt ons and stock cams. A little late spoiling dependibg what you want to do with it but great for a daily because you stay out of boost more then an early spoiling turbo.
IDK how true any of this is.
What do you hear bad about Garretts? They are near bulletproof. The problem is people improperly size them for their application and they can surge when boost control is not tuned properly. For your power level a GTX3071 would be near perfect. If you want more you can go with the 3576. I recommend staying away from the 3076. It doesn't have enough compressor for the turbine size and doesn't perform well on these cars.
This is a stock block, cams, head & IM motor. I do have most other supporting mods though as listed in my sig.
Just reading old threads I hear some people say the Garrett turbos aren't very good and others really like them on the EVO X. I'm willing to give them a shot.
Your title asks for stock frame turbo options. While the Garrett series can be mated to the stock manifold and down pipe per the ATP kit, it still is not a stock frame turbo. They come as a kit and are more expensive than a aftermarket stock frame turbo that gets bolted in. To me the ATP kits are an in between solution, between T3 and stock frame. You can make more power than with a stock frame. IMO stay stock frame on a stock motor and get a T3 or EFR kit on a built motor. A GTX35 on pump 91 @ 25 psi does not sound ideal in my opinion.
Stock frame turbos: FP are all BB now, BBX are all BB now, I have a MAP EF4 making over your number getting 20 psi at 4200 rpm at 7000 feet. EF3 might get you there too. Any of those larger stock frames would benefit from an upgraded or ported manifold. If you insist on BB, I would suggest BBX full, but I also really like my EF4
basically the bbx lite and full
I only typically recommend ball bearing in the stock housing- for best reliability!
we also have our new RB-X kits utilizing EFR turbos on our website- (of which we have already sold 10 kits in less than a month- so they are really taking off)
cb
They are already available-
cb
cb
