Catch Can vs Air Oil Separator
Alternatively you can get Radium ones. It's a bit more expensive and required more room on the intake size. I don't think it will fit if you have ETS intake.
Radium one to avoid replacing the coolant. I like to see my coolant at a glance.
http://www.radiumauto.com/Catch-Can-Kit-EVO-X-P371.aspx
I would get the radium but i already bought the driven fab. im not worried about looking at the coolant level since i could just open the radiator cap and look at it in the morning. if i really wanted to, and i might actually in the future, i could add a sight glass to the coolant side of the catch can.
running the tube shouldnt be too hard. i was going to go to home depot and by a pipe cap that will fit over it and drill a hole in the top. run the tube into the top and then run it to the fender vent. i can use a compression fitting to seal the tube to the cap and prevent vapor from exiting around the tube.
cheers
Kami Speed
EvoX 'For Sale' Engine Internals and Drivetrain
71
Feb 19, 2014 08:30 AM
Kami Speed
EvoX 'For Sale' External Engine / Power
70
Feb 19, 2014 08:28 AM
almostbuff
Dec 4, 2011 09:42 PM
maperformance
Oct 28, 2011 04:12 AM
Kami Speed
50
Sep 20, 2010 10:40 AM
