Creaking sound when stationary?
Hey guys I have a problem and I'm not quite sure whats going on. I park on an incline and every time I step in the car or get out the car it starts creak. Also when I start the car and pull out from my spot, the car creaks even harder as the wheel is being turned. I have a video below so you guys can hear the sound it makes. Anyone else ever have a problem like this? Only suspension mods I have are H&R springs. Also my E-break is kinda loose, can this be the cause?? Its been doing this for a while now, but its starting to get worse.
Thanks!
Thanks!
Does it make the sound only when you park on an incline?
Reason I ask. I have a steep driveway and anytime I park a car (family included) and only use the ebrake, it makes that sound if I don't pull it tight enough. Your ebrake might need to be adjusted.
Another thing. Not sure about the X but.... My dads truck use to make that noise when parked on a level surface. Turned out there was a bolt loose on the steering rack. I tightend it up and never did it again.
Just to give you some ideas. Let us know what you find.
popdakebin
Mar 6, 2015 10:08 PM
andymilonkis453
20
Nov 21, 2009 06:50 AM
