Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
15 MM Spacer and Lug Nut for Stock BBS
Old Dec 21, 2016, 09:23 PM
NinjaX's Avatar
Hello All, I have try searching around and I haven't found the correct answer yet.
Need Part Number and Suggestion on Spacer 15MM and Lug Nuts for them. I want to try to do what EvilYeti did to his rimes. So Gold Lug Nuts and 15MM Spacer?
I try sending him a message but did not work.
Thanks again and sorry if this one is duplicate already.
Old Dec 22, 2016, 05:25 AM
six40's Avatar
Personally I would skip the 15mm and go right to 20 or 25. I have 20's all around and it looks amazing, but some days I feel 25's would've been even better. I also got mine hubcentric with ARP extended studs, I didn't do the bolt-on style.
Old Dec 22, 2016, 10:52 AM
NinjaX's Avatar
Do you have any part number for the 20? And what lug nuts do you use?
Old Dec 22, 2016, 10:54 AM
six40's Avatar
Part number I don't remember, but I'm on the stock Enkeis so I just used the stock lugnuts. Nothing fancy.
Old Dec 22, 2016, 11:00 AM
NinjaX's Avatar
Ok thanks, i will keep looking.
Old Dec 22, 2016, 01:32 PM
acas's Avatar
Im running garage line 20mm bolt on spacers, they are hub centric to the hub and then on the outside to the wheel. Fit is perfect no vibrations or wobbles, if you running stock wheel im not sure what aftermarket lug nuts you could use because the wheels are lug centric.
Old Jan 15, 2017, 01:48 PM
NinjaX's Avatar
Thanks i just purchased a set of this from another member, will give it a try
Old Jan 27, 2017, 02:22 PM
EuRomer's Avatar
Where did you get the gold and black BBS caps?
Old Jan 28, 2017, 08:49 PM
NinjaX's Avatar
After a lot of research got them from this vendor.
https://www.nengun.com/mitsubishi/oem-parts-evo-x-final-edition
they actually added to the catalog after i request them.
GG_EVO_IX
May 23, 2013 08:55 AM
TJ4EVOTURBO
Jul 28, 2012 06:50 PM
500whp.com
Evo 'For Sale' Wheels / Tires
Jan 8, 2008 10:03 AM
nubby
Apr 24, 2005 03:46 PM
Quick Reply: 15 MM Spacer and Lug Nut for Stock BBS
