A gray area on smog
Old Jan 27, 2016, 12:46 AM
eeeeevo's Avatar
A gray area on smog
Talked to a few tuners in the Bay Area where I live about the ca smog laws. Does anyone know that if you do a tune will the car pass smog?
I'm hesitant on doing a mid level tune with 2maps
Thanks
2005 Evo 8
Old Jan 27, 2016, 02:44 AM
3gturbo's Avatar
Thanks
2005 Evo 8
A good tune running e85 is what most people use to pass it on a car with modifications.
Old Jan 27, 2016, 01:19 PM
edsct9a's Avatar
You can do a tune and also do the force obd patch on this forum and it will pass. The tune isnt the problem its the visual that can fail you. I did mine for 2015 and it passed the obd test thanks to the force patch and they no longer do the sniffer test. When Ive gone to do the tests they guys doing the smog were pretty laid back and didnt care much for the mods.
Old Feb 19, 2016, 01:09 PM
Fox_IX's Avatar
I can confirm that the force OBD patch works perfectly. Just make sure you don't enable any monitors that don't exist otherwise they'll flag your car. Just passed smog with rear 02 disabled, full tune, and all I had to do was unplug my wideband gauge.
Old Feb 19, 2016, 01:10 PM
Fox_IX's Avatar
BTW, you're in the Bay Area, I went to a smog shop in dublin to do it, i can hook you up with him. Was only $40.
Old Mar 17, 2016, 12:44 PM
goldy500's Avatar
wanna hook me up with that too
Old Oct 22, 2016, 06:44 AM
mygsx's Avatar
Thumbs up
Thanks Fox! Definitely want to stop by and check out your store and the carmeets sometime! Going to go smog next month as soon as I put my cat back on
Old Oct 22, 2016, 10:51 PM
4b11slayer's Avatar
The forced pass rom patches are to disable smog dtc. If you have the patch doesnt mean youll pass smog.
Especially a car on 91 w/out a catalytic converter.
The e85 cars passed cause they run 14.7 on the meter since the different afrs it runs clean at.
I know the smog is changing to just readiness monitors but the visual is still there.
Old Oct 23, 2016, 08:04 AM
eeeeevo's Avatar
lmk with the info. jenkinevo9@gmail.com
Old Oct 30, 2016, 09:30 PM
astral's Avatar
You can force the ECU to pass the OBDII scan. Find a place that won't be too stringent on the visual test.
Old Nov 1, 2016, 10:18 AM
wewtRallywewt's Avatar
Hey, can you also hook me up with this Dublin station's info too? Thanks! PM please
Old Nov 1, 2016, 07:44 PM
supak1111's Avatar
Not sure about CA but in IL we can pass with a lot of stuff if you read some good threads on this site. Our testing isn't by tailpipe, they just use an obd2 scanner to see if you have any codes.
PS and they check readiness of all the systems, only 1 can NOT be ready to pass.
supak111 (Nov 1, 2016)
Old Nov 2, 2016, 10:14 AM
I'm running E85 on a Tephros Flex-Fuel ROM. Will I pass smog with that setup?
P.S. I don't know much about ROM manipulation.
Old Nov 2, 2016, 11:29 AM
supak1111's Avatar
What state? How does your state emission test go? Do they actually test whats coming out of your exhaustt while they rev the **** out of your car like IL use to do, or do they just plug a computer into the OBD2 port to test (like they now do)?
I would think if they test whats actually coming out of your tailpipe you would not pass, but I'm sure someone here knows more. But if its just a OBD2 readiness test then read up on how to pass emissions on evos. You can make your ecu tell their computer that everything is ready and working well even though it may not be ;-)
Old Nov 2, 2016, 11:31 AM
kaj
kaj's Avatar
I passed with a Tune. It took me a while to get the readiness codes to show, but I eventually worked it out in the ROM.
Visual is the biggest PITA for me.
Quick Reply: A gray area on smog
