How To: 2008 Front Bumper Removal
Well here’s the tutorial for removing the front bumper for those who just can’t quite figure it out or for those who just wanted somebody to be test subject. Guess I’m the lucky guy huh.
2008 Lancer Front Bumper Removal.
Disclaimer. This tutorial was developed as a visual aid in removing the Front bumper of the 2008 Mitsubishi Lancer. In no way shall the writer be held responsible for damaged incurred on your vehicle while performing the following activities. Also note that any damage done by you will not be covered by the vehicles warranty. By performing these activities you do so at your own risk.
Any way without further a due, the main attraction.
Tools required
Philips screw driver
Flat head screw driver
Ratchet with a 10mm socket and an extension
Total time 31mins including photographs
Start
There are five metallic hex bolts on the bottom side of the bumper right in the centre. These bolts secure the bumper to bottom road debris protector covering the bottom of the block.
Remove the four Plastic Snap clips from the debris shield on bottom of the passenger side by prying out the centre piece out and remove the clips from the bumper a put aside.
The do the same from the drivers Side, this time there’s only three.
Now you will have to turn the front wheels of the car so you can get under the wheel well. Both sides are the same so it doesn’t matter which way you choose as this part applies to both sides.
In the wheel well toward the bumper are two more plastic clips, just with a Philips head. Use you Philips driver to remove these two clips.
Repeat for the other side.
Remove the screw that’s securing the bumper to the fender, normal Philips driver will do, or you can use the ratchet and 10mm socket.
Repeat on the other side
Remove the black plugs located on the lower grill hiding under the license plate and remove the two bolts there.
Pop your hood and remove your air intake by removing the two screw clips with the Philips driver.
Remove the other cover under the air intake opening, by popping the four plastic clips with a flathead driver.
Now remove the 5 Metallic bolts that hold the bumper in place, and disconnect the fog lamp connector….if you have them.
Yank…and I do mean yank the sides of the front bumper away from the car. It should be pulled up but the fender is in the way.
There is also a rather large clip located on the inside under each headlight. The gap isn’t big enough to get your hand inside to properly unlatch the clip so I just pulled some more and it popped off.
The bumper is now fully disconnected from the Vehicle and can be removed Like so…
And for those who were wondering what was behind that round cap on the front bumper
And that’s it.
Cheers,
AJ
Tools required
Start
And that’s it.
Cheers,
AJ
1 Post
Jesus, its like disarming a bomb. Cut the red wire, no no the green, wait or was that the blue.
Anyways nice job, clear and well done.
I did a hack job getting mine off lost two bolts while i was at it
as for the "screws" that hold the intake down... i was turnin em and turnin em and nothing was happening. i feel like a plastic clip it goes into underneath. how do you get these things out without breaking them? thanks!
