Console Lights All-In-One How-To
#31
If you've paid attention, now is the time to reverse all the removal and unscrewing, and get your dash back to normal. For the climate controls, if you've done everything correctly, the light guide should look like this:
#33
All in all, I would set aside a good two hours. Make sure you have all the bulbs ready to go, because it will be painful if you have to take your dash apart multiple times like me.
All my bulbs were purchased at:
http://*************************
Climate control, ashtray, cigarette lighter bulbs (#74):
http://********************/74.htm
2 for climate control
1 for ashtray
1 for cigarette lighter
Gauge cluster and auto shifter (#194):
http://********************/194.htm
2 for gauge cluster
1 for auto shifter
Do NOT use LED's, light dispersal on LED's is horrid. Only buy normal incandescent filament bulbs with the coloured glass.
Good luck.
1 for ashtray
2 for gauge cluster
1 for auto shifter
Good luck.
#34
Coloured film used for clock mod is called "theatrical gel", and is used to colour spotlights in film and theater. Can be purchased at A/V equipment stores.
I have a big sheet of leftovers, $3 via Paypal covers my cost of material and postage, you get enough gel for 2 layers of coverage.
I currently only have red, will post if I come across more colours. I've seen blue, and yellow also.
#37
I work in theatrical equipment sales, and there are tons of different gel colors you can get. By tons i mean at least 900 different shades. you can get free swatchbooks from each of the manufacturers. The size of the color swatch should be enough to do the clock. Check out the MFGRs and request free swatchbooks @ www.rosco.com, www.leefilters.com and www.gamproducts.com
#38
Outstanding friggin job...regardless of the Lancer flavor, this SHOULD help anyone out immensely...I SUGGEST making this one a STICKY...bravo! *wish I would've seen this lastnight when I installed my boost gauge...*
#39
awsome how-to jtc!! i did this all on my own w/o pics and instructions, ill tell u one thing, your write up would have saved me from a whooooole lotta swearing, lol. very sweet! o and btw, i used light condoms, red as opposed to the stock blue, instead of diff bulbs, works the same.
#44
Yeah, that bulb is tiny! I'm going to go to the dealership and see if they have any specs on it. Also, taking apart the left door panel (with the window controls), the light under the driver window control seems to just be a normal LED, which can probably be unsoldered and replaced with any other colour LED.
#45
sweeeet, now i need to just buysome blue bulbs and hope it comes out blue and not blue-green lol but if it does come out blue-green its cool...ill put some aqua neons in my ride instead of the blue, but i painted some dash pieces metallic blue but i dun care lol.
nice write up for sure!
now we need a MOD to delete all these posts and sticky this in the how-to forum!
