Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old May 7, 2007, 02:40 PM
Blacksheepdj's Avatar
All 2008 models
Lug pattern is 5x114.3
Lug nut thread/pitch - 12 x 1.5
Offset is 46mm.
Center hub is 67mm.
GTS
Stock tire size is 215/45/18
Stock tire is Dunlop SP Sport 5000 M
Wheel is 18x7
Weight of stock wheel/tire - 48 lbs. (as tested by gts_in_nj)
Weight of stock wheel - 23 lbs. (as tested by dsrttigr)
Weight of stock tire - 25 lbs. (by removing wheel weight from total weight)
DE
Stock tire size is 205/60/16
Stock tire is Yokohama AVID S34B
Wheel is 16x6.5
ES
Wheel is 16x6.5
General info
A 245/45/18 size tire will not fit, as confirmed by CrEsT (tested on 18x8 wheel). A 235-width tire will fit, however (see post #19 below).
A 16" wheel will fit on the GTS model. It is the smallest wheel that will fit, though.
Originally Posted by DaMan05's Bro
Majority of 5x114.3 bolt pattern steelies with 67.1mm centre bore will fit. This was verified by a Canadian online tire dealer and TireRack. So most Honda and Mazda steelies will work. Some old Toyota jeeps might not, offset is not close. This info is mainly for people going to the scrap yards which will save you 50-75% of the cost of steelies. Most online shops do not have the info for 2008 models, and this is handy info. Mazda3 specific steelies are the same for the Lancer.
Please post as more stats are found.
Old Jun 26, 2007, 04:18 PM
DE and ES folks are lagging behind! Post some info, folks!
Old Aug 9, 2007, 04:10 PM
Rabidhamster's Avatar
I thought I would mention that a 235 tire WILL fit
local dealership has a set on a DE.. set of 17's .. looks like stock offset and 7inch width
they were 235/45/17 and they went right up to the edge of the fenders .. looked pretty good actually.
no chance to try and swing the wheel side to side to see if they rub.. but should work
Old Sep 2, 2007, 06:25 PM
BaD2RaSS's Avatar
has anyone put 19s on their 08 what size?
Old Sep 2, 2007, 07:37 PM
SpeedI2acerX's Avatar
i got 19s w/ +35 offset 235/35/19. im thinking about going 235/45/19 if there's such a tyre size. 35 series too much road noise
Old Sep 2, 2007, 07:48 PM
kinkbmxrydr's Avatar
I have 17's with a +43 offset i think
215/45/17 tires
Old Sep 2, 2007, 09:52 PM
chachipower's Avatar
your sidewall will be bigger and your speedo will be off by a bout 5 mph (tooslow), gearing will be thrown off and fuel mileage will suffer, if you want less road noise= smaller wheel...keep your overall diameter (wheel+tire together) the same or close to stock unless you dont care about that stuff
Old Sep 4, 2007, 09:04 AM
Karan's Avatar
Thought I would throw in this tire size calculator for folks wondering about replacing their stock tire with a different size.
http://www.discounttire.com/dtcs/infoTireMath.dos
Old Oct 22, 2007, 07:24 PM
Lancer_GTS's Avatar
Anybody know what the center bore size is on the stock wheels?
This would help others in wanting to buy other wheels. (I found a set of cheap RSX wheels, and am not sure if they'll fit).
Old Nov 16, 2007, 04:58 AM
08Lancer89's Avatar
who has 20's or sick 19's and where can I find them. Post pics
Old Nov 16, 2007, 10:25 AM
NOT what this thread is for. Put that stuff in the Show & Shine forums. I want this to be about info.
Old Nov 19, 2007, 07:24 PM
DaMan05's Bro's Avatar
Anyone know what the centre bore diameter on the GTS is? Looking for steelies. I've got a set with 67.1mm wondering if that will fit.
Old Nov 23, 2007, 07:51 AM
Dumb question - why not test fit them?
LewisLancer (Jul 9, 2019)
Old Nov 28, 2007, 08:29 PM
Well I wouldn't have to make the effort if I found out they didn't. Plus they are on another car, i was planning on buying a replacement for that car and using the present ones for the Lancer. Besides you can add it to your sticky on top I found the info. Majority of 5x114.3 bolt pattern steelies with 67.1mm centre bore will fit. This was verified by a canadian online tire dealer and tire rack. So most hondas and mazda steelies will work. Some old toyota jeeps might not, offset is not close. This info is mainly for people going to the scrap yards which will save you 50-75% of the cost of steelies. Most online shops due not have the info for 2008 models, and this is handy info. Mazda3 specific steelies are the same for the Lancer.
Old Dec 19, 2007, 05:17 PM
pikahasalancer's Avatar
so the GTS is 215/45/18. i know the 18 stands for the rim size (correct me if im wrong), will 215/45/17 snow chains work on this wheel? or will that -1 inch greatly affect it?
thanks! sorry if the answer is somewhere else, i searched it but i kept getting directed to oz forums
Quick Reply: Official Wheel/Tire Info Thread
