Compiled List of all SST Oil Coolers
Old Oct 4, 2009, 02:54 PM
thrlskr's Avatar
Originally Posted by gunzo
This my DIYed setup ..
and track tested too
Look great! Can we get a part list? What improvement in temps did you see? Any logs?
Thanks,
Nick
Old Oct 28, 2009, 03:15 PM
EvoM Community Team
migs647's Avatar
Bump for updates
Old Nov 1, 2009, 05:04 AM
thrlskr's Avatar
Never mind. I see that it a kit. I thought it was a DIY job.
Old Nov 1, 2009, 08:53 AM
EvoM Community Team
migs647's Avatar
Wow there seems to be a lot more to it than I thought.
Old Nov 4, 2009, 05:20 PM
lodifreefly's Avatar
Other than mounting position, what's the difference between front and rear mount SSP kits? Is there a difference in cooling performance? Any numbers available?
Old Nov 4, 2009, 06:48 PM
gunzo's Avatar
Sorry .. mine is a DIY'ed job .. much neater / cheaper ... and copied commercially
Old Nov 17, 2009, 11:09 PM
alphawav's Avatar
wow
Originally Posted by SSP Kris
Updated pictures:
That kit is no joke..... any word if it will fit the 09+ RAs?
Old Nov 18, 2009, 08:46 AM
EvoM Community Team
migs647's Avatar
Kris, is there any temp. # difference between the rear mount and front mount?
Old Nov 19, 2009, 06:27 AM
SSP Kris's Avatar
The rear mount will tend to run around 15 to 20 degrees cooler around the track. This is due to the increased distance between the core and the transmission. The rear mount cooler also utilizes two fans, while the front uses one. We use the exact same cooler in both applications.
Kris
Old Nov 19, 2009, 02:51 PM
Arutha's Avatar
i have the blitz one sitting next to me atm. it gets installed on tuesday. only problem with it is you have to remove the fog light because of the ducting kit that comes with it.
Old Nov 19, 2009, 03:09 PM
EvoM Community Team
migs647's Avatar
That sounds hot. How much and pics of installed when you're done
Old Nov 19, 2009, 09:17 PM
Arutha's Avatar
thats the kit that comes from blitz all of the cooling ducting isn't shown in the pic however. it cost me $1300AUD
Old Nov 19, 2009, 10:58 PM
EvoM Community Team
migs647's Avatar
Could the picture be any more smaller
Where is the duct?
Old Dec 27, 2009, 10:20 AM
boondoc's Avatar
The SSP FRONT MOUNT COOLER PACKAGE is designed for both the Ralliart and the MR models. It will fit without any issues.
SSP PERFORMANCE
I am late to this one. Any modification needed? (cutting, slicing, drilling etc) Or is it jus good old fashion bolt on.
Old Jan 15, 2010, 01:41 PM
fletch's Avatar
Any word on a new pan to allow more fluid? These coolers seem like quite the job and if a fitting or hose comes loose, wow! How does the FQ360 deal with it doesn't it use the TSST as well?
Quick Reply: Compiled List of all SST Oil Coolers
