Whistling noise when boosting.
Old Oct 16, 2016, 12:11 PM
Charlie-Y's Avatar
Hello y'all,
I own a 2008 Evo Mr , as the title states , every time when I accelerate into the highway their seems to be a whistling noise like when you let out air from a balloon. Not sure if thats normal.
I owned a evo 8 before and I know this is not normal. It almost sound like a leak not with a hissing but a whistle.
I'm guessing is the bov, it is not a stock bov , the previous owner install some no name bov on it. However it could be something else.
any advise would me much appreciated.
Old Oct 16, 2016, 12:32 PM
4b11slayer's Avatar
Sounds like a boost leak. Could be the bov leaking if its cheesy.
Old Oct 16, 2016, 01:11 PM
Charlie-Y's Avatar
The car does pull, if it was a leak it wouldn't pull hard. not sure what it was. I guess I'll try a boost leak test just to be sure is not.
btw I think the bov is a ebay knock off bov. It had a soft and hard adjustment on the top.
Old Oct 16, 2016, 07:31 PM
4b11slayer's Avatar
It could be set too soft and leaking boost.
Old Oct 19, 2016, 09:04 AM
Veronica's Avatar
a small boost leak will 'whistle' and the turbo can overcome the boost loss through leak.
Just because it pulls strong or makes boost - does not rule out a boost leak.
Replace the BOV first (easiest to eliminate and pretty cheap too)
Then tighten all clamps. Yep. Pull the bumper cover to access the LICP clamps.
Then do a boost leak test if all clamps were tight and inspection for pin holes in hoses, etc...
thee stig
North Texas Evo Club (NTEC)
Jul 13, 2023 07:38 PM
rpm-evo
21
May 15, 2011 08:19 PM
KZEVO
Sep 21, 2005 06:08 PM
jrhecker
Aug 26, 2004 10:06 AM
Hanzo
Jun 24, 2003 03:52 PM
Quick Reply: Whistling noise when boosting.
