2winscrolls 800hp Cheapskate DIY build
Old Jul 3, 2015, 10:47 PM
2winscroll's Avatar
Pulling all content on this post
Old Jul 3, 2015, 10:49 PM
2winscroll's Avatar
Old Jul 7, 2015, 02:33 PM
AngryEvo8's Avatar
I'm all about the DIY kinda builds. Arp mains are proven and you will not need a dry sump setup to spin it past 8k..you can invest that money elsewhere.
Old Jul 7, 2015, 07:04 PM
doubleSUSTANON's Avatar
Another Wisconsin guy! Hooray.
Old Jul 8, 2015, 08:10 PM
2winscroll's Avatar
Too bad ya might have learned something.
Old Jul 9, 2015, 05:50 AM
AngryEvo8's Avatar
Originally Posted by 2winscroll
Thanks for the replies. Angry I was under the impression that above 8500 rpm the oil pumps fail? Or is it just an oil starvation problem? Maybe some DIY oil pan mods are in order??? I'm thinking yes to the main studs, thanks.
More of a starvation issue, you can modify the pan by adding capacity and baffles to help. Also English Racing makes a Oil pump gear designed to help as well.
Old Jul 15, 2015, 12:47 AM
project_skyline's Avatar
Oil starvation as well as belt tension when a balance shaft delete has been done are what causes failures.
Old Jul 15, 2015, 10:54 AM
Ev0ikon's Avatar
DIY is best. Did you build those twins in your avatar also?
Old Jul 15, 2015, 06:57 PM
2winscroll's Avatar
Thanks for the replies guys. I will look into the modified oil pan and see if that's something I can do or if I'll just buy one.
As for the "Twins" well those are definitely modified parts. High maintenance too just like a race car.
I'll post more pics this weekend.
Cheers
Old Jul 15, 2015, 07:13 PM
2winscroll's Avatar
Old Jul 19, 2015, 07:53 PM
2winscroll's Avatar
Old Jul 19, 2015, 11:31 PM
coloradoboost's Avatar
Interesting looks good
Old Jan 30, 2016, 08:44 PM
2winscroll's Avatar
That's not the pic I uploaded
Old Jan 31, 2016, 02:52 AM
Jonno99's Avatar
Are you still building? This started 6 months ago
Old Jan 31, 2016, 05:24 AM
IzzyRS's Avatar
Yea, let's see some progress!
Quick Reply: 2winscrolls 800hp Cheapskate DIY build
