FS[SouthEast]: Snow performance Water/Meth Injection Kit
Old Oct 27, 2015, 08:41 PM
Kustom09art's Avatar
Up for sale is a brand new Snow performance meth kit. Selling for a co-worker paid $550 Shipped to continental USA takes it in the original box complete with all parts and manual . This kit features the following clipped from the site :
Unlock 50-70HP on your boosted vehicle while decreasing your air temps by up to 150 degrees! The Snow Performance Stage 2 Boost Cooler® water-methanol injection system is available for all forced induction (supercharged/turbocharged) vehicles and uses a progressive controller that proportionally injects more or less according to boost pressure. Start and full points are adjustable for engagement and delivery curve to match what the engine requires. Proportionally injecting according to boost pressure gives an accurate delivery of water-methanol and allows cooling and performance improvements over a wide range for improved drivability. Proven to deliver 50-70 HP and reduce inlet temps by up to 150 degrees! The Stage 2 comes with a VC-20 (1-20 PSI) controller that can be mounted anywhere in the engine bay or cab for a clean install and comes with the industry leading Snow Performance 300 PSI UHO pump and Hypersonic Nozzles™ for the absolute best atomization and power available for your forced induction vehicle.
Kit Includes:
300 PSI UHO (Ultra High Output) Pump
3 Quart Reservoir
All Tubing Necessary for Installation
10’ ¼ Inch High Temp Nylon Tubing
18” High pressure Boost Line
3’ (Black) Wire Loom
Progressive VC-20 Controller
3 Wire Harness
Level Switch Upgrade
1 Nozzle Holder/Check Valve Combo
3 Hyper-Sonic™ Nozzles (175, 375, 625 ml/min) For Applications up to 1,000 HP (custom nozzles avaialble)
Required Hardware Needed For Installation
Snow Performance Running S Decal
Comprehensive Instructions to Install on Any Forced Induction Vehicle
Snow Performance 1-Year Warranty
NOTE: For use with all centrifugal superchargers (ProCharger, Vortech) and large turbos. For positive displacement superchargers (Eaton, Twin Screw) and small fast spooling turbos see (part# 212) Stage 2 MAF/MAP for best performance.
Kustom09art is offline
Old Oct 30, 2015, 04:28 PM
Price Drop!!
meat_EVO
Apr 21, 2010 04:25 PM
blackonblackevo
Apr 24, 2008 09:07 AM
TKEVO
40
Feb 7, 2008 09:38 AM
Lancematic
Sep 25, 2006 02:09 PM
Quick Reply: FS[SouthEast]: Snow performance Water/Meth Injection Kit
