Evo 8/9 Product Updates and Additions at STM
STM Tuned
43 Turner Drive
Spencerport, NY 14559
(585) 226-8226
www.stmtuned.com
STM has been doing a lot of additions and updates and our OEM section is outgrowing itself! We will soon have a new layout to make it even easier with OEM diagrams, but for now, as I track down all these OEM parts, I thought it would be handy to have some of the new stuff added accessible here in the forums and help you guys with future searching.
So, let's start here. Just added and now available!
Part Number: MD320749
Genuine OEM Mitsubishi Evo 8/9 Fuel Pressure Regulator
43 Turner Drive
(585) 226-8226
www.stmtuned.com
Just updated the STM Evo 8/9 Small Radiator Kits!
These are in stock and available now!
Part Number: STM-EVO8/9-SRAD
STM EVO 8/9 SMALL RADIATOR KIT
And we have plenty of cores to make your custom STM Billet Aluminum Radiator!
Part Number: STM-EVO8/9-BILRAD
STM EVO 8/9 BILLET ALUMINUM SLIM RADIATOR
Just finished up the OEM Evo 8/9 Intake Manifold Section.
All OEM Parts and fitments are listed and available!
Easy to find and easy to buy.
(02200) MD196781 Engine Hanger Bracket
Fits: All 2003-2006 Evolution 8/9
(02299) MF241251 Engine Hanger Bolt (M8x16mm)
* Model Specific
Fits Build Dates: (2002.12.1 - 2006.11.3)
(02299) MF241254 Engine Hanger Bolt (M8x22mm)
* Model Specific
Fits Build Dates: (2004.02.1 - 2005.07.3)
(11400) MN137746 Intake Manifold
(11410) 1540A019 Intake Manifold Gasket
(11437) MR560754 Intake Manifold Mount Bracket
(11469) MF450406 Intake Manifold Washer 10mm
(11482) MU430002 Intake Manifold Nut 10mm
(11483P) MD356697 Intake Manifold Nipple
(11483Q) MD108999 Intake Manifold Nipple 4mm
(11483S) MD107333 Intake Manifold Nipple 6.35mm
(11483T) MD072820 Intake Manifold Nipple 8mm
(11496Z) MD355625 Intake Manifold Bracket
(11496ZB) MR560744 Intake Manifold Bracket
(11498S) MF241256 Intake Manifold Bolt M8x28
(11498T) MF140056 Intake Manifold Bracket Bolt M10x16
(11498U) MF241258 Intake Manifold Bolt M8x32
(11498V) MF241284 Intake Manifold Bolt M10x30
(11498Z) MF140203 Intake Manifold Bracket Bolt M6x12
(14839) MD632057 MAP Sensor O-Ring
(14871) MF244805 MAP Sensor Bolt M5x18
(14910) MD305600 MAP Sensor w/ O-Ring
* Model Specific
Fits: 2003-2004 Evolution 8
(14910) MN153281 MAP Sensor w/ O-Ring
* Model Specific
Fits: 2005-2006 Evolution 8/9
Shop at www.STMTuned.com!
* Model Specific
* Model Specific
* Model Specific
* Model Specific
Just finished up the AEM X Series Gauges. They are all available at the lowest MAP pricing in an easy to find layout.
Gauges are currently in stock, ready to ship.
AEM X-Series Digital Gauges & Faceplates
Competition Clutch Kits and Replacement Parts are all cleaned up, organized and added!
SO much easier to find what you need!
CCI Single & Multi Clutch Kits w/ Disc Options
CCI Replacement Discs & Pressure Plate for Single Disc Kits
Competition Clutch Evo 8/9/X Twin Rebuild Parts
Competition Clutch Evo 8/9/X Triple Rebuild Parts
This was a big one! Great reference and hopefully it will help with any EvoM searching.
All parts are listed and available online for purchase!!
OEM Mitsubishi 2003-2006 Evolution 8/9
Engine Cylinder Block Diagram
We've also got the full replacement set of main studs here:
Diagram Number 01300A (MN137516)
Evo 8 4G63 Cylinder Block
For 2003-2005 Evolution VIII
Diagram Number 01300A (1050A060)
Evo 9 MIVEC 4G63 Cylinder Block
For 2006 Evolution IX MIVEC
Diagram Number 01305 (MD372046)
Oil Jet Check Valve
Fits all 2003-2006 Evolution 8/9
Diagram Number 01321 (MD363826)
Oil Baffle Plate
Diagram Number 01381 (MN143460)
Oil Jet Squirter
Diagram Number 01385 (MS661142)
Cylinder Block Plug 3/8" Taper
Diagram Number 01385P (MD378291)
BSPT 1/16" Cylinder Block Plug
Diagram Number 01385Q (MD040338)
Diagram Number 01385S (MD065945)
Cylinder Block Plug Screw 10mm
Diagram Number 01386 (MF472550)
Oil Jet Spring Pin
Diagram Number 01387 (MF472403)
Cylinder Block Dowel Pin 6x14
Diagram Number 01395 (MF665541)
Freeze Plug 35mm
Diagram Number 01395P (MF665542)
Freeze Plug 40mm
Diagram Number 01396P (MD020260)
Cylinder Block Dowel Pin 10.5x19.3
Diagram Number 01396Q (MS471104)
Cylinder Block Dowel Pin 8x9
Diagram Number 01396S (MS471111)
Cylinder Block Dowel Pin 12x13
Diagram Number 01397P (MD153368)
Main Stud Bolt
Diagram Number 01397T (MD183236)
Main Stud Bolt
Diagram Number 01397Q (MF140204)
Rear Main Seal Housing Bolt M6x14
Diagram Number 01397Z (MF244849)
Baffle Plate Bolt M8x16
Diagram Number 03017 (MD311550)
Diagram Number 03080 (MD359158)
Rear Main Crankshaft Oil Seal
Diagram Number 03601 (MD040597)
Balance Shaft Bearing (FR)
* Plain / STD Size
Diagram Number 03601 (MD082301)
* Plain / 1.00 Oversized
Diagram Number 03602L (MD040598)
Balance Shaft Bearing (RR LH)
* Plain / STD Size
Diagram Number 03602L (MD082302)
Diagram Number 03602R (MD103722)
Balance Shaft Bearing (RR RH)
* Plain / STD Size
Diagram Number 03602R (MD103723)
Diagram Number 04911 (MD343884)
Engine Oil Dipstick Level Gauge
Diagram Number 04912 (MN183590)
Engine Oil Dipstick Guide Tube
Diagram Number 04956 (MF140021)
Dipstick Tube Mounting Bolt
Diagram Number 04999 (MD075834)
Dipstick Tube Bottom O-Ring
Diagram Number 04999 (MD317089)
Dipstick Gauge Top O-Ring
Oil Jet Check Valve
Oil Baffle Plate
Oil Jet Squirter
Oil Jet Spring Pin
Freeze Plug 35mm
Freeze Plug 40mm
Main Stud Bolt
Main Stud Bolt
* Plain / STD Size
* Plain / STD Size
* Plain / STD Size
cficare68
Dec 21, 2017 08:39 AM
badev0
Feb 1, 2017 06:01 AM
STM Tuned
EvoX 'For Sale' External Engine / Power
Jan 7, 2015 08:17 AM
