INSTALLED: Evo IX SpoolinUp COP & Denso IKH24 plugs
First of all I will start by mentioning my car has 46k miles on it with untouched stock NGK spark plugs and have never once given me any ignition problems or misfires.
Yesterday I removed the stock coil/boots/wires and installed the SpoolinUp COP setup (used coil version) retaining the stock spark plugs (untouched, never removed) to see if there would be a noticeable difference. I will note that my coils/boots/wires came out of my car appearing to be in perfect condition with no noticeable wear or discoloring of any sort.
This thing obviously looks amazing in the engine bay, the only thing I'm not impressed with is how the one coil plug touches the o2 sensor plug. This makes me think the passenger side coil should be rotated slightly clockwise in order to fit better.
At first I didn't really notice a difference at all with the COP installed, but after a bit more driving around it does seem to be revving up smoother when leaving from a stop and the low-RPM (<2000) drivability definitely seems smoother (this is huge for me since I have FP4R cams). It's tough to say whether or not this smoothness can be credited to the COP or if it just means my stock wires/boots were due for replacement. It does seem that even people with very low mileage IX's are still reporting this same improvement in smoothness though. DAY 1 COMPLETE and I am satisfied with my purchase thus far!
Today I removed my stock spark plugs and overall they look very good as well. Again, they never once gave me any ignition problems or misfires that I noticed. I believe they look very good especially considering their age and show my car to be in good running condition with a proper tune. This is the first time the stock spark plugs were ever removed from my engine and are currently sitting at a (from passenger to driver side) .025", .025", .023", .027" gap (factory spec is .020-.024" gap).
Although I generally am a fan of NGK, I decided to replace my stock spark plugs with Denso IKH24 iridium plugs since I wanted to go 1 heat range cooler due to my mods and increased boost level (26 psi peak with the stock turbo). They came out of the box pregapped to .030-.031" and I left them there; very tight consistency which I haven't seen with plugs I've bought for other cars in the past. I installed them with a small amount of high-temp copper anti-seize on the threads and some dielectric grease on the top.
Here are the final installation pictures:
The car felt and pulled very smooth during the final test-drive. With the new plugs the car felt even smoother yet and did seem to pull a bit cleaner into the high RPM's. With the gaps set to .030-.031" there was no break-up or misfires. It would have been interesting to see how the car performed with the new plugs using the stock coils/boots/wires, but I don't feel like tearing everything apart again since I'm very satisfied with the end result.
DAY 2 RESULTS are impressive, I'm glad I did this round of modding. It is not a night and day difference like some are claiming, but it does make a nice subtle change leading to a smoother driving car. I'm not going to make any horsepower claims or estimates since that should only be done with dyno sheets as backup/proof.
Silver Sponsor
Looks good man!
On a side note, take the COP off, you may be able to rotate the #1 coil a bit more torward the hump on the valve cover. There is purposely a bit of play in them. I'll have to add in a piece onto my IX valve cover for final fitment to avoid that in the future.
