Water Injection Setups
Old Dec 5, 2010, 02:56 PM
mt057's Avatar
Here are some more of my favorite bits...
A little bling with my blue bezel DDS3
I have my dinosaur lm-1, HFS-3 ecu and FAV tucked up behind my glove box. The HFS-3 ecu fits perfectly in the upper right hand corner. I left plenty of extra wire attached in case I decide to move it later.
Here is my comp. T fitting. I use the comp. fittings all around and have not had a leak since.
Old Dec 5, 2010, 04:04 PM
EvoTio's Avatar
Yes, thanks for posting some more detailed pics of the tank. Definitely well worth the investment. I can also attest that those compression fittings has sealed up any minor leaks that I've had. It seems that I may have another Aquamist project in the future and I will defintely consider that tank .
Old Dec 6, 2010, 01:21 AM
Richard L's Avatar
mt057.
Thank for those pictures, did you colour the gauge bezel yourself? Looks good.
Old Dec 6, 2010, 01:25 AM
Richard L's Avatar
More adaptor news...
For alternative jet adaptor options, Jeff at Howerton engineering has them all:
Old Dec 6, 2010, 05:40 AM
mt057's Avatar
Acutally Jeff from Howerton Engineering got a few of the gauges from you guys a while ago and had them aniodized while the bezels were still raw. He had one red, blue, black , and silver made. I managed to get the blue one.
Old Dec 10, 2010, 12:36 AM
Richard L's Avatar
I re-do the brightness level via photoshop, took some of the glare off.
Old Dec 11, 2010, 12:50 AM
drifterific's Avatar
This is my current set up with -4an fitting with an engine bay pump install utilizing the stock intercooler sprayer res. I need to repaint some of the fittings that the purple did not stick too. Ill sand them down next time around or send them off to be powder coated.
Here are some pics of the old set up
Old Dec 11, 2010, 07:27 AM
EvoTio's Avatar
drifterific, very well done with the braided lines and fittings . That's the only way I'd do my set up if I were to ever run pure methanol injection.
Old Dec 11, 2010, 10:06 PM
im only running 50/50 but I wanted to make sure that my set up did not leak and it looks good too. I plan on building a new all aluminum res to take place of the stock plastic res.
Old Dec 12, 2010, 01:54 PM
mt057's Avatar
Nice pics thanks for posting up! I like the -an lines. What did you paint the connections with?
I don't think that using a bare aluminum tank would be a good idea. Are you going to coat it with something? I have never tried it before just curious.
Old Dec 12, 2010, 02:07 PM
Richard L's Avatar
Pretty impressive transformation with those AN lines. Looks menacing.
Old Dec 13, 2010, 12:07 AM
Thank you Richard. I need to post this up on your forums also.
Old Dec 13, 2010, 12:15 AM
Richard L's Avatar
That would be great, our forum could do with some new posts.
Old Dec 13, 2010, 12:59 AM
tim85851's Avatar
heres my setup:
Old Dec 18, 2010, 07:29 PM
9evolution's Avatar
Anyone use the perrin kit? wife gave me a perrin pw2 for xmas. I asked for cams she got me meth
Quick Reply: Water Injection Setups
