Ignited Push Button Ignition kit
Old May 10, 2005 | 06:13 PM
Mitsubeastin's Avatar
I was wonderin if anyone knows how this works?
Old May 10, 2005 | 07:06 PM
amg_dragon's Avatar
You still need to have your key turned to the on position, then you push the button and it takes over for that last 1/8" of an inch you normally do with the key. It's a rice thing unless you actually have a full out race car... or a honda 2000. It essentially take over the starter relay.
Old May 10, 2005 | 07:49 PM
bruce988jl's Avatar
someone told me it was better than the key method for some reason.. i think it stresses your car less because it's not like you're holding the key in the "start position" and doublestarting the engine like i see some people do...? i'm not sure.. just what i heard
Old May 11, 2005 | 06:02 AM
sillypuddy's Avatar
you can do this yourself.. chop your stock wires and then just wire in a relay and a switch
-joe
Old May 29, 2005 | 06:08 PM
Smokin Lancer's Avatar
Joe~ Are you should that will work?
Old May 29, 2005 | 07:49 PM
CF-Ninja's Avatar
whats so hard about turning a key?
Old May 30, 2005 | 06:37 AM
sillypuddy's Avatar
it will work
when you turn the key to the "crank" position, you are just completing the circuit..
-joe
