How do I remove bubbles under vinyl??
Old Nov 7, 2005 | 08:37 AM
ddcha's Avatar
I just put on my 3-diamond badge overlays. Front went on perfect but the rear has bubbles trapped inside. Is there a quick fix (like a hairdryer or something)?
Old Nov 7, 2005 | 08:43 AM
imajinmyfx's Avatar
yeh .. try heat or take a neddle and pop the bubble
Old Nov 7, 2005 | 08:45 AM
Silver05Bullet's Avatar
If the vinyl is already on then try to push the air bubble out with a cradit card, if that doesnt work best bet is get a small needle pierce a hole where the air is and then push the air out thru the hole you should not be able to see the hole just use a small needle.
Since its an overlay u should be able to push it out with a cradit card because of the small area. U can use some heat as you said in your original post
Old Nov 7, 2005 | 09:06 AM
ddcha's Avatar
Thanks guys. Acupuncture sounds like a good alternative. I was afraid to take the hairdryer to it because I thought it might go "shrinky-dink" on me.
amsevokid
Sep 7, 2013 08:34 PM
ILikeApples
Northwest Region
Apr 18, 2012 03:55 PM
Devgamer
Northwest Region
Jan 16, 2012 11:05 AM
cush87
Jul 18, 2011 02:59 PM
Bubbles
Lancer Troubleshooting
Sep 1, 2002 07:55 AM
