Loss of Power on Take Off
Old Jul 24, 2006 | 02:28 AM
MyRoN's Avatar
Okay heres what going on NOW, Never ending Problems with My rallliart.
Okay when taking off in 1st gear, it seems to be Very Sluggish until i hit about 3k rpms then it pick up speed, now i tried hearing form a vcuume leak, but its hard when u the one driving. Any way to check for a vacuume leak with out taking it into a shop, here in az, they tend to charge out the A$$ for things.
Need some help on this, thanks
Old Jul 24, 2006 | 04:03 AM
lanzerralliart's Avatar
EvoM Super Moderator
you only have this problem in 1st?
Old Jul 24, 2006 | 07:04 AM
Myszkewicz's Avatar
What are your mods?
If it's a vacuum leak, you should be able to locate it with the engine running while parked. I've never heard of a car having a vacuum leak only when driven. There aren't very many vacuum hoses on a Ralliart. There's a large one that goes to your brake booster, and a small one that goes to an evaporative emission purge solenoid. If you have a vacuum gauge, you can attach it to the nipple where the evap purge solenoid is attached (it's on the throttle body), and measure your vacuum at idle. You should have at least 18 in Hg at idle.
Try resetting the ECU, too. It might have a setting stored that's killing your low-end power.
Old Jul 24, 2006 | 07:53 AM
MyRoN's Avatar
I have a SRI and thats it,
Yes this only happens in 1st, its sluggish, then after 3k rpms, it feels normal
Old Jul 24, 2006 | 07:47 PM
wrecked's Avatar
Arizona huh.... A/C on? I know its a stupid question, but you never know.
Old Jul 24, 2006 | 10:36 PM
morpheus256's Avatar
I know with the heat we've been ahving here lately, my car feels slower, just like it doesent have as much grunt to get it moving.
Old Jul 24, 2006 | 10:41 PM
DangerousDan's Avatar
Is this at every takeoff or just after you start the car? (cold start or all the time) I have a DIY CAI and at cold start it doesn't create any power until 2k rpm's or so until the third or fourth takeoff (less than a minute due to my neighborhood.) I ignore it because I know it's not a problem with the car. If you get an auto mechanics stethascope it is very easy to detect small air and vacuum leaks.
Old Aug 21, 2006 | 01:17 PM
Ralli04Art's Avatar
its turbo lag..........
Old Aug 21, 2006 | 02:21 PM
otter's Avatar
EvoM Administrator
Sounds like a combination of having the AC on and high heat. The problem should go away in the fall.
Old Aug 21, 2006 | 06:23 PM
AdamRA's Avatar
Old Sep 13, 2006 | 12:15 PM
ralliarv's Avatar
With the SRI sounds like the sluggish issue could be heatbog or being heat soaked from the stop.
Old Sep 13, 2006 | 02:47 PM
NewRA's Avatar
hey man I feel the same way with my car, it only happens in 1st gear, I just thought that's the way our cars are....probably the weight of our cars
Old Sep 13, 2006 | 03:51 PM
I don't have that problem, 1st there is no traction, 2nd there is a bit in the end , 3rd chirps.... must just be the lightly modded ra ?!? anyone else?
Old Sep 15, 2006 | 09:14 AM
BlackRaven's Avatar
In addition to temperature-specific things (ie. A/C on, hot outside, etc.)....how long have you had your wheels? I don't know which model of R1's you have, but the 18" size may have added a couple of lbs.
IMO, in your "Coming up Soon" list, replace eyelids with the RRM UD pulley...after that, A/C no problem
Old Sep 16, 2006 | 05:30 PM
04lancerEsGuy's Avatar
You need one of these...One of the big ones...Actually, no let's make it two & you need them by tonight.
