O2 sensor problem
Old Jan 23, 2009 | 03:29 PM
wake's Avatar
O2 sensor problem
Today I was trying to get off the O2 sensor (the one after the cat) on the exaust to install a CEL eliminator but I couldn't unscrew it. I've tried to put some rust stuff but it has doesn't change anything!!!
Do you have tips to get it off??? It should be an easy job, I don't want to spend money jsut for that little thing!!!
Old Jan 23, 2009 | 05:56 PM
Myszkewicz's Avatar
Heat the threaded part with a torch. If you can get it to glow faintly red, it should come right out with an O2 sensor socket or box end wrench.
Old Jan 23, 2009 | 06:39 PM
spota's Avatar
get a box wrench and get extra leverage with a piece of steel pipe slid over the wrench. i've done it before.
Old Jan 23, 2009 | 07:47 PM
wake's Avatar
heating it won't break the O2 sensor?
To put the box wrench on the O2sensor, I'll need to unplug the sensor!!! Is that difficult?
Old Jan 23, 2009 | 09:25 PM
spota's Avatar
not at all but you could use an open ended wrench if you're worried of breaking the connector/s.
Old Jan 24, 2009 | 05:26 AM
wake's Avatar
I've tried qith the open wrench...it doesn't work at all!!! One corner of the sensor as slip!!!
Old Jan 24, 2009 | 08:04 AM
otter's Avatar
EvoM Administrator
Use an O2 sensor socket, that's what they're for.
Old Jan 24, 2009 | 11:17 AM
wake's Avatar
Where can I find one???
Old Jan 24, 2009 | 11:41 PM
SLO-EVO's Avatar
try your local parts store... its better that you unplug the sensor, because if/when you do start taking it off, you dont want to twist the wires and tear them. majority of your o2 sensors are unclipped... i dont know which one you are trying to remove...
Old Jan 24, 2009 | 11:42 PM
SLO-EVO's Avatar
one more thing, if you want, if you cant find an already made one at your local store, you can make your own as well... just die-grind out a slot on the socket you can fit over the sensor.
Old Jan 25, 2009 | 06:58 AM
wake's Avatar
I'll try with the socket...I'll buy one at Canadian Tire and refund it 1 week after!!! They take back everything in good shape!!!
Thanks for all the help!!!
Old Sep 11, 2014 | 12:14 PM
RalliEvo06's Avatar
Sorry to bump an ancient thread but where would I get a CEL ELIMINATOR
Old Sep 11, 2014 | 07:29 PM
CrAnSwIcK's Avatar
almost anywhere...
google "O2 sensor spacer"
Old Sep 12, 2014 | 06:44 AM
RalliEvo06's Avatar
I have like 3 de-foulers in and it'd giving the light still.
Old Sep 12, 2014 | 07:05 AM
CrAnSwIcK's Avatar
what's the code?
