Rattle in Bumper
Old Oct 26, 2005 | 10:02 AM
ox663bender's Avatar
Rattle in Bumper
I am having a rattle in my bumper anyone know what it is? and anyone have some good ideas about the vibration in trunk....
Old Oct 26, 2005 | 10:34 AM
psychlancer's Avatar
I have the same thing, its a mystery to me. Mine rattles on the drives side rear between the gas tank and tail light. Maybe its one of those road side mitsu guys (like the commercial) stuck in there?
Old Oct 26, 2005 | 11:12 AM
yea mine is on the same thing... i am thinking about taking the bumper off and checking it out... but i'd really like to know because it sounds like poop.
Old Oct 26, 2005 | 11:40 AM
SerialX's Avatar
"To much junk in the trunk". Whoa Im sorry that was completely gay.
Old Oct 26, 2005 | 11:44 AM
jdizzy's Avatar
between my exhaust and my system my car rattles all over... I would check all your bolts and tighten them down really good...
yeah that was gay... maybe you should think before you type... but seriously it is like there is something like rattling inbetween the quarter panel and the inside of the trunk rattleing
Old Oct 26, 2005 | 09:53 PM
otter's Avatar
EvoM Administrator
A rock or something probably got in there.
Old Oct 26, 2005 | 10:56 PM
Myszkewicz's Avatar
Vent. I'd bet a dollar.
Old Oct 26, 2005 | 11:34 PM
Nissaka's Avatar
There was a forum that went over how to eliminate noise rattle from sub's in the trunk. The guy used shoe pads I used socks, however it took away all the rattle. Try it, it might work might not.
Old Oct 27, 2005 | 08:32 AM
r3z0nate's Avatar
Where do you come up with those pictures
Old Oct 28, 2005 | 10:12 AM
EnJaNir's Avatar
I have recentlyfound that I also have that rattle. It sounds as if it is coign from between the drivers side rear fender and the trunk. I have removed all the trunk lineing (dropped 2 of the center push pins) and have the rear seats completley out. I can't believe it is the 2 pins that are causing this much noise, but it is randon, usually during bumpy road. I have checked the vents which have been mentioned and they do not produce a noise similar to what I am hearing. Tonight I'm going to climb in the trunk and have my dad drive to try to determine the location of this annoying rattle.
Old Oct 28, 2005 | 06:02 PM
05ES's Avatar
Could be a noob question but, what does the vent do?
A little off topic but wondering if removing it will have any adverse side effects
Old Oct 28, 2005 | 06:35 PM
Myszkewicz's Avatar
It's just a flapper valve covering a hole for air to flow through. When you're driving around with the vent, heater, or A/C on, bringing in fresh air, and have all the windows and sunroof closed, some air has to be able to get out in order for new air to come in.
I found them when I went looking for whatever it was that made the noise in the trunk when I closed my door after parking the car.
I can't think of any adverse effects to your HVAC system, but you may find mice taking up residence in your trunk if you remove the flappers.
Old Oct 28, 2005 | 10:18 PM
fi you close up the vents in the back it will cause a vacum effect when you try to shut your doors, this well not alow you to close you car doors right. well that is waht the dealer told me today.
Old Oct 28, 2005 | 11:02 PM
NonEvo's Avatar
no idea what the rattle is, but shouldnt this be in the RA general forum and not the Show and Shine
