Spring Fling 07
Old Jan 23, 2007 | 09:16 AM
GoMikey's Avatar
Spring Fling 07
Any one coming to spring fling? hoping to bodydropped by then but who else is going with what mods?
Old Jan 25, 2007 | 02:32 PM
zboy's_lancer's Avatar
where's it at and when
Old Jan 25, 2007 | 02:43 PM
Cj98's Avatar
would also like to know
Old Jan 25, 2007 | 09:03 PM
ev-slo's Avatar
body drop?
Old Jan 25, 2007 | 09:21 PM
CF-Ninja's Avatar
Maybe try the Southeast regional forum.
https://www.evolutionm.net/forums/southeast-region-43/
May have better luck there.
Old Jan 25, 2007 | 11:24 PM
AdamRA's Avatar
Originally Posted by ev-slo
body drop?
Sheets of LSD under your arms....
I'm sure he means lowered.......
Old Jan 26, 2007 | 09:02 AM
GoMikey's Avatar
march 10 and 11 in panama city florida and no i MEAN BODYDROP
Old Jan 26, 2007 | 09:29 AM
AdamRA's Avatar
bodydrop? Please explain
Old Jan 26, 2007 | 03:06 PM
Cj98's Avatar
on bags
Old Jan 26, 2007 | 04:28 PM
AdamRA's Avatar
That explains why I nothing about it Save it for the Monte Carlo J/K
Old Jan 26, 2007 | 06:41 PM
sP33Dy's Avatar
How the F*ck do u BodyDrop a lancer that has it's main chasis integrated into the shell!??? It's not a truck!
For those not in the know technically .... A bodydrop is where the floors are cut and raised, so the body sits OVER the chasis, making the body look lower, minimising interior height, but at the same time makes the body lower to the ground so u can 'lay frame / body' with airbags.
( Noobs, read up! : http://en.wikipedia.org/wiki/Body_drop#channeling )
Old Jan 30, 2007 | 09:39 AM
GoMikey's Avatar
ok sp33dy i agree a traditional bodydrop is done the way you have stated above and the artilce is a great write up about the procedure although on a unibody its a modified bodydrop therfore you raise the struttowers. therefor loweing the placment of the body of the car. this will alow the body to sit lower and to be "bodydropped" the term is loosly used as to a suspension mod although in reality the suspension is staying stock to an extent while u are raising where the stock struts mount to frame by altering in the raising and lowering the body allowing it to rest lower. i hope this clears up any confusion
Old Jan 30, 2007 | 01:31 PM
AdamRA's Avatar
someone explain the point I don't get it????
Old Jan 30, 2007 | 01:33 PM
sP33Dy's Avatar
Plleeease post some updated pics & info of your car on bags in the following thread!
https://www.evolutionm.net/forums/sh...=147226&page=2
Old Jan 30, 2007 | 01:37 PM
Deepseadiver's Avatar
I should still be in Panama City, FL might have to check it out.
dsm2308
Midwest Region
Mar 21, 2009 04:34 PM
manofhonor
Oct 1, 2008 08:52 AM
Adamk24
Oct 5, 2007 01:22 PM
nic411
Mar 12, 2007 06:26 PM
