well ill post it here just in case other ppl wanted to get the sunroof dealie out:
1. take off the handle part, thers 4 screws from the top, pta #1. along with the rubber pieces that stop it from sliding all the way back. i still cant get them back in tho
2. pull it back as hard as you can while still being kinda careful of the motor n stuff of the sunroof, i broke off a lot of clips doing this. but i dont think anything bad will come of that
3. try n not scratch tint
that sucked
4. shove it all back hahaha
overal its all working fine, aside from the rubber dealies that i couldnt get back in, when i move the screen back it hits the roof or something hard n sounds bad
that sucked4. shove it all back hahaha
Quote:
Originally Posted by MITVRX
You sound like your the first for everything. Good on you.
thats because im the man. You know, i should change my name from Ralliart_on_LSD to simply GOD.
how do you take off the a b c pillars?.. is it just removal of the black strip? please reply bc i dont want to rip them off and be effd
Quote:
for the b pillars you have to take off the seat belt peice that has the little button peice and then you need a 13mm wrench I think it is and just take it off Originally Posted by ohfourLancer
for the C pillars just take it off like the A start at the top and work down
Originally Posted by Cj98
for the b pillars you have to take off the seat belt peice that has the little button peice and then you need a 13mm wrench I think it is and just take it off for the C pillars just take it off like the A start at the top and work down
oh so there is no removal of that black rubber trim? just pull it off starting from the top?
Quote:
actually start pulling the stripping off and it will make things alot easierOriginally Posted by ohfourLancer
Quote:
you pay for the flight hahaOriginally Posted by Achilles
Wanna fly to Connecticut to do mine? LOL looks fantastic.
take the weather stripping off? no but when I put things back I realized it was better
Quote:
what did u go with flat black or gloss for the visors, pillars n ohh s*it handles?Originally Posted by Cj98
