RA projectors
Old Feb 4, 2009 | 08:35 AM
  #61
Raikiri's Avatar
If I'm not mistaken... being HID compatible just means having the reflectors to be able to focus the HID light better or else the non compatible ones will just have the light bouncing all over the place... I dont really see how it'd be different though unless they added something into the housing...
As for the pictures... Does the white and bronze bolt only adjust the projector? or do they adjust the Highbeams as well? Will a phillips screwdriver work with them?
Old Feb 4, 2009 | 03:10 PM
  #62
gjgfrombigd's Avatar
http://www.hidplanet.com/forums/viewtopic.php?t=2080
Old Feb 16, 2009 | 08:23 PM
  #63
Momak's Avatar
I don't know what they mean by HID compatible, maybe that they just weren't designed with HIDs in mind. Either way, I've got them ebay ones and have HIDs in them for awhile now, nothing's happened (yet). Putting in the HIDs, I think I had to mess around with the wiring to get it to work the right way, so that's another thing to think about. They split the 9007 into two bulbs, and you may wish to consider doing something about the DRLs as well if you have them. as for the adjustment, at least from my observations it seemed like only one screw adjusted the projector while the other adjusted the high beam. A Philips screwdrive works, but I found one of the screws, if the screwdriver's too long, you dont get enough space to work with it. A stubby one I imagine could fit, or you could also use a socket and ratchet to adjust it as well.
Old Feb 17, 2009 | 05:55 PM
  #64
pics of the cutoff?
Old Feb 17, 2009 | 08:48 PM
  #65
rory_j13's Avatar
baby evo where did you pick up that grill
Old Feb 17, 2009 | 09:41 PM
  #66
BABYEVO1's Avatar
its the stock grill for the 06 RA
Old Feb 18, 2009 | 06:40 AM
  #67
What'd you want for your stockies?
Old Feb 18, 2009 | 10:35 AM
  #68
rory_j13's Avatar
dam it looks nice i doubt it would fit on my 04. I plan on painting mine silver so it matches the rest of the car
blackandredgts
13
Jan 7, 2014 09:14 AM
Lancerzz
Oct 16, 2012 01:36 PM
dee242
Oct 26, 2010 07:18 AM
Onkar02
Apr 13, 2009 05:46 PM
