Constant Side Blinkers?
Old Feb 29, 2004 | 09:31 PM
RalliartJP's Avatar
Question about side blinkers. Is it possible to have them on constant, and then have them blink when you put the turn signal on? If so, does anyone know how to do it, or which wire to re-wire? Cause I was thinking of changing them to hyper white....?
Old Mar 8, 2004 | 10:18 PM
RalliartJP's Avatar
55 Views and nobody has nothing to say...damn, i guess im beat...
Old Mar 9, 2004 | 06:58 AM
Deltarider99's Avatar
There has to be a way, because I see cars all the time that have them on all the time. I would try doing a general search on the web for diagrams and schematics and such...one side-marker can't be too much different from the next; they're just plastic covers, bulbs and wires.
Old Mar 9, 2004 | 07:14 AM
CoronaLancer's Avatar
Splice the wire that goes to your headlight into the side marker.
Old Mar 9, 2004 | 07:54 AM
xstephenx's Avatar
^^And if you want them on all day(not just with headlights) you can always just find a wire that goes hot when your ignition is switched on and just hook them up to that. You can basically just rip the wires that are there out of the blinker circuit and rewire them. If you have a lead tester/voltmeter/etc. it will probably only take you 5-10 minutes to wire once the wires are found and stuff.
Old Mar 9, 2004 | 08:00 AM
^yup it's easy on our car. All the ground wires are black and the live wires are colored.
