Polishing the heat shield
Old Sep 12, 2004 | 08:56 AM
otter's Avatar
EvoM Administrator
Hey all, I'm thinking about polishing the heat shield for the header. Does anyone have any tips/recommendations on how to do this without leaving any scratches?
Old Sep 12, 2004 | 10:41 AM
blk-majik's Avatar
Its pretty rough, so it will be a long job, but should turn out nice. If you have a grinder wheel /w a very soft steel brush, start /w that but go light, caus if u scratch too deep, u got alot of sanding to do! Then get some sandpaper and and touch it up. this might take a couple of hours and alot of sandpaper. If you dont have a grinder, just go straight to the sandpaper or start /w a steelwool brush or pad (not the soap ones!). Then, if you have a dremel or something similar, use the polish tool to finish /w a good steel polish.
Old Sep 15, 2004 | 08:54 AM
95TsiAWD's Avatar
I just used sandpaper to start 180 - 200 - 320 - 480 - 600 then used the white polishing compound on a side grinder with a buffing wheel and then used some Mother's Aluminum polish. Turned out mirror shiny, there's a pic of it on the forums somewhere.
Old Sep 15, 2004 | 08:44 PM
tyler's Avatar
https://www.evolutionm.net/forums/sh...0&page=1&pp=15
however the pics haved 404ed, do you think you could maybe repost them? I would be interested in doing this as well
Old Sep 16, 2004 | 10:46 AM
95TsiAWD's Avatar
I'll upload them when I get home
Old Sep 17, 2004 | 01:02 AM
fifty1fifty's Avatar
I'm workin on doing mine. Starting with 320 wet sanding, then 400, then red compound on a wheel. That gets any scratches from the 400 out.
