04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Cat Back Size
Old Apr 10, 2005 | 04:53 AM
JohnathanKong's Avatar
Cat Back Size
I just have a quick question, how big is too big for a cat back? I will be running 5 PSI, and my friends say that a 3" cat is too big. Is this true? And if so, when I run 12 PSI, sould I upgrade to a 3"? Thanks.
Old Apr 10, 2005 | 06:32 AM
DiamondWhite's Avatar
depends on what route you go.... to be honest if you go turbo, there is the possibility of needing a bigger exhast but not till after like 15-20 psi, if you go supercharger, it's a differen t setup and won't need as much backpressure
Old Apr 18, 2005 | 06:47 AM
pinoynoskillz's Avatar
rrm says 2.5 is the perfect size. don't quote me on that.
Old Apr 18, 2005 | 07:16 AM
blk-majik's Avatar
I think 2.5" should do fine under any daily driven situation. Last I checked, TTPR was still using 2.5" exhaust and putting out about 600hp.
Old Apr 18, 2005 | 12:58 PM
ooralliartoo's Avatar
my buddy with his old 240 had a 3 inch straight pipe. it's not too big...in japan the sylvia's came stock with a 3 inch straight pipe
Old Apr 18, 2005 | 05:52 PM
Widebody Lancer's Avatar
turbo = bigger the better the turbo itsself creates the nessary back pressure to not pull fuel out on exhaust - intake stroke
Old Apr 18, 2005 | 06:18 PM
ask turbotech_P.R. ^_^
Old Apr 20, 2005 | 01:35 AM
Thanks for the input. I think I have decided to go with the 3" catback so that when I go higher HP, the flow will be better for my turbo.
