Injector leaking
Injector leaking
The last injector on the fuel rail is leaking fuel under full boost only. Not a lot but it should be fixed. I'm guessing Ralliart also has a returnless system. It's not an emergency cause they're working fine on regular driving. Any ideas what to do?
do you have an aftermarket pump? I don't remember
more pressure=more leaking.
either replace the o-rings or if you had to customize the fuel rail to get it bolted down with the aftermarket injectors you could have either too much pressure or not enough pressure on the o-rings to seal properly. too much pressure and they will bind, too little and... well that's obvious.
more pressure=more leaking.either replace the o-rings or if you had to customize the fuel rail to get it bolted down with the aftermarket injectors you could have either too much pressure or not enough pressure on the o-rings to seal properly. too much pressure and they will bind, too little and... well that's obvious.
Replace the o-rings and make sure they're properly seating in the rail. If it's leaking form the rail, the o-ring is bad, and the excessive fuel pressure at full boost is overcoming the seal of the o-ring.
The fuel pump is stock. It shows that it's more than capable of supplying enough fuel. I have an Evo 9 pump I was gonna put in, but it might not be necessary. Is the Ralliart returnless also? Does it have to be converted to return, or are the o rings enough?
RA is returnless yes.
Definately sounds more like an o-ring or injector seating problems. Make sure you tight them firmly and BTW what size injectors you got? For returnless system I recomend running at least 500cc's.
stock pump, rail, and aftermarket injectors? did you have to customize the rail at all to get them to fit? using wrx injectors you would have to make the rail mount further away, for instance. if you needed to finagle something that is most assuredly where your problem is starting. after checking the condition of the o-rings I would start checking my fitment.
I'm sure it's a combination of things that lead to an already failing seal to break.
I think your best bet is to just put new o-rings on. It's really not that difficult and it'll prevent an engine bay fire. Any gas leak within the engine bay is serious for obvious reasons. There are several flash points under the hood of a car that could ignite gas vapors and leaks.
Ok guys, it's fixed. We had to put a different washer on and tighten it up a bit. No leak under boost. And the engine doesn't shake anymore when idling either. I guess there was a bit of air leak around the injector.
